We would like to know how we can able to switch back from the application to SBL(Secondary bootloader) again after the completion of the warm reset through the watchdog timer. For your information we are using this location #define SBL_VECTOR ((uint32_t) 0xE000ED08) where our SBL resides. So our assumption is that once the warm reset is done it will go to this specified SBL location and trigger the SBL. But this respective functionality is not happening, So we would like to know how we can achieve this and what changes need to be made.
We can provide more information if required.
NOTE: we are using SDK 05_04_00_01 version, and TI has provided an example code for warm reset called watchdog reset . so we have merged this example code with the example hello world code, we have attached that respective code changes here for your reference.
/* * Copyright (C) 2018-2021 Texas Instruments Incorporated * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the * distribution. * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ #include <stdio.h> #include <kernel/dpl/DebugP.h> #include <kernel/dpl/ClockP.h> #include <kernel/dpl/HwiP.h> #include <drivers/watchdog.h> #include "ti_drivers_config.h" #include "ti_drivers_open_close.h" #include "ti_board_open_close.h" //#include "transport.h" //#define SBL_VECTOR ((uint32_t) 0xE000ED08) #define SBL_VECTOR 0x00458000 volatile uint32_t *vtor; #define NUM_OF_ITERATIONS (3U) void app_switchtoSBL(); void app_switchtoSBL() { DebugP_log("Switching to SBL"); *vtor = SBL_VECTOR; #if (!UNIT_TEST) __asm(" MSR MSP, %0" : :"r" ((uint32_t)*vtor)); //__asm("BX %0"::"r" ((uint32_t)*(vtor))); __asm("BX %0"::"r" ((uint32_t)*(vtor+4))); #endif } void hello_world_main(void *args) { /* Watchdog timer expiry time in millisecond */ uint32_t wdtExpiryTimeinMs = gWatchdogParams[CONFIG_WDT0].expirationTime; uint32_t index = 0; /* Open drivers to open the UART driver for console */ Drivers_open(); Board_driversOpen(); DebugP_log("Hello World!\r\n"); Watchdog_enable(gWatchdogHandle[CONFIG_WDT0]); DebugP_log("Watchdog reset Mode Test Started ...\r\n"); DebugP_log("Servicing WDT for few iterations \r\n"); /* Service the WDT for more than expiry time */ for(index = 0; index < NUM_OF_ITERATIONS; index++) { /* Need to service the WDT in open window */ while(Watchdog_isClosedWindow(gWatchdogHandle[CONFIG_WDT0]) == true); /* Clear Watchdog timer */ Watchdog_clear(gWatchdogHandle[CONFIG_WDT0]); /* wait for (expiry time/2 ) time */ ClockP_usleep((wdtExpiryTimeinMs*100)/2); } DebugP_log("Watchdog triggers warm reset in %d (ms)\r\n", wdtExpiryTimeinMs); DebugP_log("All tests have passed!!\r\n"); /* Wait till WDT triggers the reset */ while(1) { DebugP_log("Prints will be stopped after reset mcw \r\n"); } app_switchtoSBL(); DebugP_log("stopped watchdog!!\r\n"); // Board_driversClose(); // Drivers_close(); }
