Other Parts Discussed in Thread: TDC7200, TDC1000
Hello! Is there an easy way of using the TDC7200 as the stopwatch when using the TDC1000 evaluation board? If not, is there a suggested way of pairing them together?
Also, how do you recommend we account for the time taken to transmit the wave through the tank material when using an externally mounted transducer? Is there a better way than simply calibrating with known liquids?
For reference, we are attempting to very accurately measure the speed of sound in some fluids for which it is unknown, so we need absolute values, not relative values (as was demonstrated in the application report).
Thank you!
