AWR2944: We met this problem,how can I fix it.Can you give me some advices?The problem is "Wildcards are not permitted in output section, GROUP or UNION names".
Part Number: AWR2944
Hi Ti support,
Building target: "RB22_AlvBoot_r5ffss0_nortos.out"
Invoking: Arm Linker
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Og -DFBL_SUPPORT -DNDEBUG -DOS_NORTOS=True -DSOC_AWR294X=True -g -Wall -Wno-unused-function -Wno-gnu-variable-sized-type-not-at-end -Wno--extra -mno-unaligned-access -fno-common -Wl,-m"RB22_AlvBoot_r5ffss0_nortos.map" -Wl,-i"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/lib" -Wl,--reread_libs -Wl,--diag_suppress=10063 -Wl,--mapfile_contents=sym_defs -Wl,--xml_link_info="RB22_AlvBoot_r5ffss0_nortos_linkInfo.xml" -Wl,--trampolines=on -Wl,--ram_model -Wl,--zero_init=on -o "RB22_AlvBoot_r5ffss0_nortos.out" "./boot/FFBL/fbl_boot/src/fbl_boot.o" "./boot/FFBL/gen_syscfg/ti_board_config.o" "./boot/FFBL/gen_syscfg/ti_board_open_close.o" "./boot/FFBL/gen_syscfg/ti_dpl_config.o" "./boot/FFBL/gen_syscfg/ti_drivers_config.o" "./boot/FFBL/gen_syscfg/ti_drivers_open_close.o" "./boot/FFBL/gen_syscfg/ti_enet_config.o" "./boot/FFBL/gen_syscfg/ti_enet_lwipif.o" "./boot/FFBL/gen_syscfg/ti_enet_open_close.o" "./boot/FFBL/gen_syscfg/ti_enet_soc.o" "./boot/FFBL/gen_syscfg/ti_pinmux_config.o" "./boot/FFBL/gen_syscfg/ti_power_clock_config.o" "./boot/FFBL/src/fbl_main.o" "./common/services/fls_dir/src/fls_dir.o" "./common/ti_sdk/mcu/source/board/flash/flash.o" "./common/ti_sdk/mcu/source/board/flash/qspi/flash_nor_qspi.o" "./common/ti_sdk/mcu/source/drivers/bootloader/bootloader.o" "./common/ti_sdk/mcu/source/drivers/bootloader/bootloader_flash.o" "./common/ti_sdk/mcu/source/drivers/bootloader/soc/awr294x/bootloader_soc.o" "./common/ti_sdk/mcu/source/drivers/bootloader/soc/awr294x/bootloader_utils_addrxlate.o" "./common/ti_sdk/mcu/source/drivers/edma/v0/edma.o" "./common/ti_sdk/mcu/source/drivers/pinmux/awr294x/pinmux.o" "./common/ti_sdk/mcu/source/drivers/qspi/v0/edma/qspi_edma.o" "./common/ti_sdk/mcu/source/drivers/qspi/v0/qspi.o" "./common/ti_sdk/mcu/source/drivers/soc/awr294x/soc.o" "./common/ti_sdk/mcu/source/drivers/soc/awr294x/soc_rcm.o" "./common/ti_sdk/mcu/source/drivers/uart/v1/uart_sci.o" "./common/ti_sdk/mcu/source/drivers/uart/v1/uart_sci_edma.o" "./common/ti_sdk/mcu/source/kernel/nortos/dpl/common/AddrTranslateP_null.o" "./common/ti_sdk/mcu/source/kernel/nortos/dpl/common/ClockP_nortos.o" "./common/ti_sdk/mcu/source/kernel/nortos/dpl/common/DebugP_log.o" "./common/ti_sdk/mcu/source/kernel/nortos/dpl/common/DebugP_nortos.o" "./common/ti_sdk/mcu/source/kernel/nortos/dpl/common/DebugP_uartLogWriter.o" "./common/ti_sdk/mcu/source/kernel/nortos/dpl/common/SemaphoreP_nortos.o" "./common/ti_sdk/mcu/source/kernel/nortos/dpl/common/TaskP_nortos.o" "./common/ti_sdk/mcu/source/kernel/nortos/dpl/common/TimerP_rti.o" "./common/ti_sdk/mcu/source/kernel/nortos/dpl/common/printf.o" "./common/ti_sdk/mcu/source/kernel/nortos/dpl/r5/CacheP_armv7r.o" "./common/ti_sdk/mcu/source/kernel/nortos/dpl/r5/ClockP_nortos_r5.o" "./common/ti_sdk/mcu/source/kernel/nortos/dpl/r5/CpuId_armv7r.o" "./common/ti_sdk/mcu/source/kernel/nortos/dpl/r5/HwiP_armv7r_handlers_nortos.o" "./common/ti_sdk/mcu/source/kernel/nortos/dpl/r5/HwiP_armv7r_vim.o" "./common/ti_sdk/mcu/source/kernel/nortos/dpl/r5/MpuP_armv7r.o" "./common/ti_sdk/mcu/source/kernel/nortos/dpl/r5/PmuP_armv7r.o" "./common/ti_sdk/mcu/source/networking/enet/hw_include/cpdma/csl_cpdma.o" "./common/ti_sdk/mcu/source/networking/enet/hw_include/emac/V5/priv/csl_cpgmac_sl.o" "./common/ti_sdk/mcu/source/networking/enet/hw_include/mdio/V5/priv/csl_mdio.o" "./common/ti_sdk/mcu/source/networking/enet/hw_include/mdio/csl_mdio.o" "./core/hp/FBL_Support/src/fbl_support.o" "./core/hp/ppar/src/ppar.o" "C:/RB22/RB22_TASK/rb22_code/Alvboot_Check/rb22_software_core/sw/build_env/common_linker.cmd" "C:/RB22/RB22_TASK/rb22_code/Alvboot_Check/rb22_software_core/sw/build_env/ffbl_linker.cmd"
makefile:228: recipe for target 'RB22_AlvBoot_r5ffss0_nortos.out' failed
"C:/RB22/RB22_TASK/rb22_code/Alvboot_Check/rb22_software_core/sw/build_env/ffbl_linker.cmd", line 65: fatal error:
tiarmclang: error: tiarmlnk command failed with exit code 1 (use -v to see invocation)
gmake[1]: *** [RB22_AlvBoot_r5ffss0_nortos.out] Error 1
