I found below info at MMWAVE_L_SDK_05_04_00_01/docs/api_guide_xwrL14xx/CFARPROC_PAGE.html.
CFAR DPU when the input is range-doppler detection matrix
Would you pls give more info about maximum along doppler dimension (above red rectangle)? How it works? Is above CFAR 2D CFAR or 1D CFAR? I can see it did CFAR on range dimension. It uses different process on doppler dimension.
Chris
