Other Parts Discussed in Thread: AWR2243
A previous post mentioned the noise figure in awr2243 datasheet is double sideband. How about in awr2944?
The question is a little misleading. In AWR2944 we support real-only receive, not full complex. However, both the positive and negative frequencies are real, so you will measure the same SNR if you look at positive or negative spectrum. Anyway, it shouldn't impact your calculations, you can use the NF as stated in the DS.
James
The reason I asked is based on this question.
https://e2e.ti.com/support/sensors-group/sensors/f/sensors-forum/922935/awr2243-awr2243-noise-figure-question-dsb-nf-or-ssb-nf
It says AWR2243's NF is based on complex mode. In real mode, the NF will be 3dB worse.
AWR2944's 13dB NF is based on real mode, so we should not add 3dB to it in our link budget calculation, correct?
