Part Number: AWRL1432
Hi team,
I want to check how to close the RDIF interface? Can I close the clock system for RDIF interface by setting adcLoging to ‘0’ to improve the EMI performance?
Shawn
Hi team,
Shawn
Hi Shawn,
One of our engineers will look into this and give you an answer within a day or two.
Hi Shawn,
You can try adclogging 2 which will switch off the RDIF interface
Sreedeep
Hi Sreedeep,
In our code, setting 2 means SPI and setting 0 is close this rdif. Can you help confirm this?
Shawn
Hi Shawn,
Setting 2 will enable raw data capture through SPI, where RDIF will be closed. I will confirm if adclogging 0 will turn off the RDIF.
Sreedeep
Hey Shawn,
By default, the RDIF clock - the MDLL clock derived from APLL clock - is disabled, so setting the adcLogging to 0 or 2 should keep the RDIF disabled. If adcLogging is set to 1, then the clock is enabled.
Kristien
