Other Parts Discussed in Thread: UNIFLASH, AWR2944, SYSCONFIG
Hello, we want to replace the flash chip matching the 2944. Refer to the sprach9e document to confirm that WINBOND's W25Q32JV chip is available. We modified the syscfg according to the mmwave_mcuplus_sdk_04_04_01_02\mmwave_mcuplus_sdk_04_04_01_02\tools\custom_flash\W25Q32JVSQ.json file. we have modified the syscfg files of sbl_uart_uniflash, sbl_qspi, and appimage related projects, and used mmwave_mcuplus_sdk_04_04_01_02\mcu_plus_sdk_awr294x_09_00_00_15\examples\drivers\boot\sbl_uart_uniflash related operations to burn.But the burning is unsuccessful, please tell us the correct method.
Visible attachments using syscfg file
* These arguments were used when this file was generated. They will be automatically applied on subsequent loads
* via the GUI or CLI. Run CLI with '--help' for additional information on how to override these arguments.
* @cliArgs --device "AWR294X" --package "ETS" --part "Default" --context "r5fss0-0" --product "MCU_PLUS_SDK_AWR2944@09.00.00"
* @versions {"tool":"1.14.0+2667"}
* Import the modules used in this configuration.
const flash = scripting.addModule("/board/flash/flash", {}, false);
const flash1 = flash.addInstance();
const adcbuf = scripting.addModule("/drivers/adcbuf/adcbuf", {}, false);
const adcbuf1 = adcbuf.addInstance();
const cbuff = scripting.addModule("/drivers/cbuff/cbuff", {}, false);
const cbuff1 = cbuff.addInstance();
const crc = scripting.addModule("/drivers/crc/crc", {}, false);
const crc1 = crc.addInstance();
const edma = scripting.addModule("/drivers/edma/edma", {}, false);
const edma1 = edma.addInstance();
const edma2 = edma.addInstance();
const ipc = scripting.addModule("/drivers/ipc/ipc");
const mcan = scripting.addModule("/drivers/mcan/mcan");
const mcan1 = mcan.addInstance();
const mibspi = scripting.addModule("/drivers/mibspi/mibspi", {}, false);
const mibspi1 = mibspi.addInstance();
const uart = scripting.addModule("/drivers/uart/uart", {}, false);
const uart1 = uart.addInstance();
const uart2 = uart.addInstance();
const clock = scripting.addModule("/kernel/dpl/clock");
const debug_log = scripting.addModule("/kernel/dpl/debug_log");
const mpu_armv7 = scripting.addModule("/kernel/dpl/mpu_armv7", {}, false);
const mpu_armv71 = mpu_armv7.addInstance();
const mpu_armv72 = mpu_armv7.addInstance();
const mpu_armv73 = mpu_armv7.addInstance();
const mpu_armv74 = mpu_armv7.addInstance();
const mpu_armv75 = mpu_armv7.addInstance();
const mpu_armv76 = mpu_armv7.addInstance();
const mpu_armv77 = mpu_armv7.addInstance();
const mpu_armv78 = mpu_armv7.addInstance();
* Write custom configuration values to the imported modules.
flash1.$name = "CONFIG_FLASH0";
flash1.device = "CUSTOM_FLASH";
flash1.flashSize = 4194304;
flash1.flashManfId = "0xEF";
flash1.flashDeviceId = "0x4016";
flash1.flashQeType = "5";
flash1.fname = "W25Q32JV";
flash1.peripheralDriver.$name = "CONFIG_QSPI0";
adcbuf1.$name = "CONFIG_ADCBUF0";
cbuff1.$name = "CONFIG_CBUFF0";
crc1.$name = "CONFIG_CRC0";
edma1.$name = "CONFIG_EDMA0";
edma1.instance = "EDMA_DSS_B";
edma1.regionId = 0;
edma1.edmaRmDmaCh[0].resourceType = scripting.forceWrite("ownDmaCh");
edma1.edmaRmDmaCh[0].$name = "CONFIG_EDMA_RM0";
edma1.edmaRmDmaCh[0].startIndex = 0;
edma1.edmaRmDmaCh[0].endIndex = 63;
edma1.edmaRmQdmaCh[0].$name = "CONFIG_EDMA_RM1";
edma1.edmaRmTcc[0].$name = "CONFIG_EDMA_RM2";
edma1.edmaRmTcc[0].startIndex = 0;
edma1.edmaRmTcc[0].endIndex = 63;
edma1.edmaRmParam[0].$name = "CONFIG_EDMA_RM3";
edma1.edmaRmParam[0].startIndex = 0;
edma1.edmaRmReservedDmaCh[0].$name = "CONFIG_EDMA_RM4";
edma1.edmaRmReservedDmaCh[0].startIndex = 0;
edma1.edmaRmReservedDmaCh[0].endIndex = 0;
ipc.r5fss0_1 = "NONE";
ipc.vringNumBuf = 1;
ipc.vringMsgSize = 1152;
mcan1.$name = "CONFIG_MCAN0";
mcan1.MCAN.RX.$assign = "ball.D16";
mcan1.MCAN.TX.$assign = "ball.D17";
mibspi1.$name = "CONFIG_MIBSPI0";
mibspi1.bitRate = 600000;
mibspi1.t2cDelay = 0x5;
mibspi1.c2tDelay = 0x5;
mibspi1.dataSize = 8;
mibspi1.frameFormat = "POL0_PHA1";
mibspi1.advanced = true;
mibspi1.csHold = true;
mibspi1.instance = "MIBSPIB";
mibspi1.MIBSPI.$assign = "MIBSPIB";
mibspi1.MIBSPI.CLK.pu_pd = "nopull";
mibspi1.MIBSPI.CLK.$assign = "ball.T13";
mibspi1.MIBSPI.MISO.pu_pd = "nopull";
mibspi1.MIBSPI.MISO.$assign = "ball.U13";
mibspi1.MIBSPI.MOSI.pu_pd = "nopull";
mibspi1.MIBSPI.MOSI.$assign = "ball.V12";
mibspi1.mibspiChannel[0].$name = "CONFIG_MIBSPI_CH0";
const edma3 = edma.addInstance({}, false);
edma3.$name = "CONFIG_EDMA2";
mibspi1.edmaConfig = edma3;
edma3.edmaRmDmaCh[0].resourceType = scripting.forceWrite("ownDmaCh");
edma3.edmaRmDmaCh[0].$name = "CONFIG_EDMA_RM10";
edma3.edmaRmQdmaCh[0].$name = "CONFIG_EDMA_RM11";
edma3.edmaRmTcc[0].$name = "CONFIG_EDMA_RM12";
edma3.edmaRmParam[0].$name = "CONFIG_EDMA_RM13";
edma3.edmaRmReservedDmaCh[0].$name = "CONFIG_EDMA_RM14";
uart1.$name = "CONFIG_UART1";
uart1.intrEnable = "DISABLE";
uart1.baudRate = 3125000;
uart1.UART.$assign = "UARTB";
uart1.UART.RX.$used = false;
uart1.UART.TX.$assign = "ball.A14";
uart2.$name = "CONFIG_UART0";
uart2.baudRate = 921600;
uart2.UART.$assign = "UARTA";
uart2.UART.RX.$assign = "ball.B16";
uart2.UART.TX.$assign = "ball.C16";
edma2.$name = "CONFIG_EDMA1";
flash1.peripheralDriver.edmaConfig = edma2;
uart1.edmaConfig = edma2;
uart2.edmaConfig = edma2;
edma2.edmaRmDmaCh[0].$name = "CONFIG_EDMA_RM5";
edma2.edmaRmQdmaCh[0].$name = "CONFIG_EDMA_RM6";
edma2.edmaRmTcc[0].$name = "CONFIG_EDMA_RM7";
edma2.edmaRmParam[0].$name = "CONFIG_EDMA_RM8";
edma2.edmaRmReservedDmaCh[0].$name = "CONFIG_EDMA_RM9";
debug_log.enableLogZoneError = false;
debug_log.enableLogZoneWarning = false;
mpu_armv71.$name = "CONFIG_MPU_REGION0";
mpu_armv71.attributes = "Device";
mpu_armv71.allowExecute = false;
mpu_armv72.$name = "CONFIG_MPU_REGION1";
mpu_armv72.size = 14;
mpu_armv73.$name = "CONFIG_MPU_REGION2";
mpu_armv73.baseAddr = 0x80000;
mpu_armv73.size = 14;
mpu_armv74.$name = "CONFIG_MPU_REGION3";
mpu_armv74.baseAddr = 0x10200000;
mpu_armv74.size = 20;
mpu_armv75.$name = "CONFIG_MPU_REGION4";
mpu_armv75.attributes = "NonCached";
mpu_armv75.size = 14;
mpu_armv75.baseAddr = 0x102EC000;
mpu_armv76.$name = "CONFIG_MPU_REGION5";
mpu_armv76.baseAddr = 0xC5000000;
mpu_armv76.size = 13;
mpu_armv76.attributes = "NonCached";
mpu_armv76.allowExecute = false;
mpu_armv77.$name = "CONFIG_MPU_REGION6";
mpu_armv77.baseAddr = 0xA4030000;
mpu_armv77.size = 12;
mpu_armv77.attributes = "NonCached";
mpu_armv77.allowExecute = false;
mpu_armv78.$name = "CONFIG_MPU_REGION7";
mpu_armv78.baseAddr = 0x88000000;
mpu_armv78.size = 21;
mpu_armv78.attributes = "Cached+Sharable";
mpu_armv78.allowExecute = false;
* Pinmux solution for unlocked pins/peripherals. This ensures that minor changes to the automatic solver in a future
* version of the tool will not impact the pinmux you originally saw. These lines can be completely deleted in order to
* re-solve from scratch.
flash1.peripheralDriver.QSPI["0"].$suggestSolution = "ball.U11";
flash1.peripheralDriver.QSPI["1"].$suggestSolution = "ball.V11";
flash1.peripheralDriver.QSPI["2"].$suggestSolution = "ball.T11";
flash1.peripheralDriver.QSPI["3"].$suggestSolution = "ball.R12";
flash1.peripheralDriver.QSPI.$suggestSolution = "QSPI0";
flash1.peripheralDriver.QSPI.CLK.$suggestSolution = "ball.R10";
flash1.peripheralDriver.QSPI.CS.$suggestSolution = "ball.U12";
mcan1.MCAN.$suggestSolution = "MCANA";
mibspi1.mibspiChannel[0].MSS_CSn.$suggestSolution = "ball.U14";
