Other Parts Discussed in Thread: AWR2544
Hi,TI Team:
We can see "profile_3d_3Azim_1ElevTx_DDM_awr2544_1Xmode.cfg" and "profile_3d_3Azim_1ElevTx_DDM_awr2544_2Xmode.cfg" in the profiles file of 2544. The "ethPktRdyCnt" in the "procChainCfg" CLI parameter uses different values, one is set to 530, the other is 6(Figure 1), and the two values are quite different. I have learned from relevant documents that ethPktRdyCnt in 1xmode should be calculated according to the formula in the following figure(Figure 2). However, the documentation does not yet see how this value should be calculated in 2xmode. Can you provide the relevant calculation method of this value in 2xmode?
Figure 1:
Figure 2:
Best Regards
Jack
