Other Parts Discussed in Thread: UNIFLASH,
Hi, Gurus,
I almost copied AWR2944EVM design, i.e. PROC113D version. I changed the flash IC to GD25Q64EWIGR.
But I can't flash firmware, the Uniflash error is as following.
I tested the voltage of flash IC, and found QSPI_D1 DC voltage is 2.4V, although I used a 10K pullup to 3V3_VIO.
I used omnimeters to find that V11 pin of AWR2944 has a resistor to GND, and the resistor is about 20K--40K. So that QSPI_D1 DC voltage is dropped down to 2.4V.
I want to know how to set V11 pin to high-Z before flash? Or any other solution?
Tony Liu
PS: Flash Error message:
[2024/8/21 下午2:34:22] [INFO] Cortex_R5_0: Initialization complete.
[2024/8/21 下午2:34:22] [INFO] Cortex_R5_0: Sending UART Uniflash image at location C:\ti\uniflash_8.6.0\deskdb\content\TICloudAgent\win\ccs_base\mmWave\gen2/images/sbl_uart_uniflash.release.tiimage
[2024/8/21 下午2:34:41] [ERROR] Cortex_R5_0: XMODEM send failed, no response OR incorrect response from EVM OR cancelled by user, power cycle EVM and run this script again !!!
[2024/8/21 下午2:34:41] [INFO] Cortex_R5_0: UART Uniflash image sent.
[2024/8/21 下午2:34:41] [INFO] Cortex_R5_0: Sending SBL image at location E:/Fangjiajia/TDM/sbl_qspi.release.tiimage
[2024/8/21 下午2:34:51] [ERROR] Cortex_R5_0: XMODEM send failed, no response OR incorrect response from EVM OR cancelled by user, power cycle EVM and run this script again !!!
[2024/8/21 下午2:34:51] [ERROR] Cortex_R5_0: XMODEM recv failed, no response OR incorrect response from EVM OR cancelled by user,Power cycle EVM and run this script again !!!
[2024/8/21 下午2:34:51] [INFO] Cortex_R5_0: SBL image sent
[2024/8/21 下午2:34:51] [INFO] Cortex_R5_0: Sending Appimage at location E:/Fangjiajia/TDM/awr2944_corner_radar_921600_points.appimage
[2024/8/21 下午2:34:51] [INFO] Cortex_R5_0: Appimage sent
[2024/8/21 下午2:34:51] [INFO] Cortex_R5_0: Instance deinitialized!
