Hi teams,
Customer has questions regarding to the product HDC2010.
- Just want to clarify if the turning on test process is correct: Sensor at sleep mode(default) >> Trigger on Demand mode >> Turn OFF the system but keep the sensor ON>> Read the maximum humidity data from the sensor after it turn on again
- what state should other pins remain after setting up the system? As the system go OFF after setting up, should SDA/SCL/INT state stay unchanged as before(OFF)?
Thanks for the help.
Liang Tsai
