Other Parts Discussed in Thread: PGA900
Hi dear Ti members,
last time I connected my PCB to XDS200 debugger, it worked ok, until I made some change on my PCB then when I wanted to connect the power supply to the PCB, I don't know exactly what happened but a short circuit because of wire under PCB made my XDS200 broken. And it doesn't work anymore, no connection with PC and LEDs they are always off.
In this case, I want to know that is there any Isolation between power supply and output inside PGA970 and also how can I use "Galvanic isolation" or any other tricks to isolate the Output and power supply and also on the Debugger side.
If you have any Idea or same experience, please let me know.
Thank you
Haßan
