AWR2243BOOST: antenna parameters
Part Number: AWR2243BOOST
Other Parts Discussed in Thread: AWR2243,
Hello, I would like to ask for information about the antenna parameters of the AWR2243 millimeter wave sensor, I did not find that specific information in the technical documentation you provided.
AWR2243 is a three-transmitter-four-receiver antenna, and the antenna parameters I would like to know are:
(1) Is the orientation map of each array element consistent and are they pointing at the same pointing direction
(2) The directional map parameters of the array elements
(3) Whether the beam angles of the transmitter elements overlap each other or each points in a different direction
(4) The transmitting power of the sensor
Thank you for your time.
    Thank you for reaching Texas instruments.
    1. All antennas do point in the same direction on the AWR2243BOOST EVM.
    2. Can you please elaborate on this request? Have you referred to the EVM userguide?
    3. The beam from each TX will overlap
    4. The typical transmit power of the sensor is 13dBm.
    E. Shareef
