Hi there,
I'm trying to do elevation estimation using virtual channel 8 and 12 since there is vertical separation between them. I avoided FFT since the resolution would be poor and therefore I chose to do phase interferometry. As discussed in the TI MIMO processing document, I found the phase difference between channel 8 and channel 12 and then processed to get angles however the results I received are not correct.
Can you confirm that my estimation method is correct?
