LM95241: Compatibility check with respect to sensing diodes
Part Number: LM95241
Other Parts Discussed in Thread: ADC12DL2500, TMP461
I am interfacing LM95241's 1st channel with Virtex ultrascale+ FPGA and 2nd channel to ADC12DL2500 TDIODE pins.
  1. Can you please share which parameters to check from sensor datasheet to ensure that the sensor can read the full-scale temperature changes that happens in the ADC diode?
  2. Below is the design implementation. Can you please confirm if it's ok and no other terminations are required?
Thank you
