TMAG5231: Bop and Brp Datasheet Discrepancies
Part Number: TMAG5231
Hello E2E Experts,
Good day.
I am trying to find the correct setup for Hall sensor/switches I want to use and I am using the TIMSS tool for that. However, I found that some of the product specs seem wrong, e.g.
TMAG5231H1DQDBZR: BOP is 0.04 mT and BRP is 0.034 mT, while the data sheet says, that it should be BOP: 40 mT and BRP should be 34 mT (so wrong unit by factor 1000 - I noted this on many of the products that are available there).
TMAG5231H1DQDMRR: BOP and BRP should be same as the above, but they are completely different.
Could you please review the specs u entered, and amend them? Otherwise it is difficult to find the proper setup (of course there are workarounds, but it is cumbersome).
Regards.
TI-CSC
  • TI-CSC,
    Thank you for checking on this.  We are already aware of this mismatch and the effort is underway to get everything re-aligned.  The way the data was being stored in the central database was updated for our devices, and this has caused the TIMSS tool to be impacted.  We are working through fixing this presently, but do ask for some patience as we get everything back into alignment.  We should have all of the work done in the next day or so.
    Thank you,
    Scott
