AWR2544LOPEVM: clock synchronization through gPTP issue (Ethernet TSN CPSW gPTP TimeReceiver (gPTP Slave) Example)
Part Number: AWR2544LOPEVM
Other Parts Discussed in Thread: AWR2544
I am trying to run the example Ethernet TSN CPSW gPTP TimeReceiver (gPTP Slave).
For that I have a Linux PC taking the role of master clock and I want my AWR2544 LOP EVM clock being synchronized with my Linux PC one.
At the moment this is the terminal output whre we see that 'not asCapable' is always raised and 'computed Proptime' is always out of range:
Also here is Linux PC output :
So here are my question:
1) do you have any idea on how to make this clock synch working?
2) In the SDK, for this example there is a "PPS ouput" chapter which is very confusing for me. For example I can't configure the same syscfg as the one presented in screenshot. Can you clarify what is expected here please ?
Many thanks for your help.
Jean-François Oberle
  • Hi Jean,
    What is the SDK version you are using?
    Also, I do not see the syscfg screenshot in this E2E.
    Ajay
  • Hi Ajay,
    1) I am using the last available SDK version: 04_06_01_02
    2) regarding syscfg, in 'PPS output' folder of Ethernet TSN CPSW gPTP TimeReceiver (gPTP Slave) Example , there is this syscfg screenshot:
    Which doesn't match with the provided example syscfg of the AWR2544:
    Thank you for the help!
  • Hi Jean,
    Are you using the standard example or made any modifications to the same?
    Shruti
  • Hi Shruti,
    I am using the standard example as provided in the SDK. No modification has been added.
    Thanks.
    Jean-François
  • Hi Jean,
    For now, you can ignore the pps output section in the syscfg, this configuration is not provided in the current release. If you want to configure the pinmux for that pin then you can do the same from the code.
    For the example, are you getting the time difference any time or you are just getting the error whatever you have shared in the previous screenshots? Can you check the logs for a longer time.
    I have tried running the same example at my end and it is working as expected for me. I am not getting the out of range Proptime in any case. I'm sharing my logs here, you can take it as a reference.
    /cfs-file/__key/communityserver-discussions-components-files/1023/gptp-logs.txt
    Can you clarify the following things -
    1. share the config file details that you are running on Linux machine.
    2. are you using any switch to get the ethernet connectivity between the pc and EVM?
    3. are you using the industrial PHY or AUTO PHY to test the same?
    4. mention all the steps that you are following to run the example.
    Shruti
  • Hi Shruti,
    I am sharing here the serial terminal log of my new attempt. As you can see I always have this "computed PropTime is out of range" error message. Log file:
              gPTP App
    start to open driver.
    Init all configs
    sitara-cpsw: init config
    sitara-cpsw: Open port 1
    EnetPhy_bindDriver: PHY 0: OUI:080028 Model:23 Ver:01 <-> 'dp83867' : OK
    PHY 0 is alive
    sitara-cpsw: Create RX task for regular traffic
    initQs() txFreePktInfoQ initialized with 8 pkts
    MAC port addr: 70:ff:76:1d:ec:f2
    unibase-1.1.4
    INF:cbase:tilld0: has mac: 70:FF:76:1D:EC:F2
    Start: uniconf_task
    sitara-cpsw: default RX flow started
    EnetApp_uniconfTask: dbname: NULL
    INF:uconf:simpledb_open:no data is imported
    INF:uconf:uc_hwal_open:
    INF:cbase:cb_rawsock_open:combase-1.1.3
    INF:cbase:cb_rawsock_open:dmaTxChId=-1 numRxChannels=0 dmaRxChId=-1 nTxPkts=0 nRxPkts=0 pktSize=0
    INF:uconf:create_semname_with_dbname:null dbname is specified.
    INF:cbase:cb_lld_task_create:alloc stack size=16384
    INF:uconf:000000-275784:uniconf_main:uniconf started
    EnetApp_gptpYangConfig:domain=0
    INF:uconf:get_exmodid_in_db:first xl4gptp:exmodid=0
    EnetApp_gptpNonYangConfig:XL4_EXTMOD_XL4GPTP_SINGLE_CLOCK_MODE=1
    EnetApp_gptpNonYangConfig:XL4_EXTMOD_XL4GPTP_USE_HW_PHASE_ADJUSTMENT=1
    EnetApp_gptpNonYangConfig:XL4_EXTMOD_XL4GPTP_CLOCK_COMPUTE_INTERVAL_MSEC=100
    EnetApp_gptpNonYangConfig:XL4_EXTMOD_XL4GPTP_FREQ_OFFSET_IIR_ALPHA_START_VALUE=1
    EnetApp_gptpNonYangConfig:XL4_EXTMOD_XL4GPTP_FREQ_OFFSET_IIR_ALPHA_STABLE_VALUE=4
    EnetApp_gptpNonYangConfig:XL4_EXTMOD_XL4GPTP_PHASE_OFFSET_IIR_ALPHA_START_VALUE=1
    EnetApp_gptpNonYangConfig:XL4_EXTMOD_XL4GPTP_PHASE_OFFSET_IIR_ALPHA_STABLE_VALUE=4
    EnetApp_gptpNonYangConfig:XL4_EXTMOD_XL4GPTP_MAX_DOMAIN_NUMBER=1
    Start: gptp2d_task
    EnetApp_initTsn:TSN app start done!
    INF:cbase:cbl_query_response:tilld0 link DOWN !!!!
    INF:gptp:gptpman_run:max_domains=1, max_ports=1
    INF:cbase:cb_rawsock_open:dmaTxChId=1 numRxChannels=1 dmaRxChId=1 nTxPkts=8 nRxPkts=16 pktSize=1536
    INF:cbase:rxChId 1 has owner dmaRxShared 0
    INF:gptp:dev:tilld0 open success
    INF:gptp:gptpnet_init:Open lldtsync OK!
    INF:gptp:IEEE1588-2019 performance monitoring disabled.
    INF:uconf:ydbi_get_item_ifk3vk0:no data
    INF:gptp:onenet_activate:tilld0 status=0, duplex=1, speed=0Mbps
    INF:ubase:GPTP_MEDIUM_ALLOC: fragsize=16 fragused/fragnum=604/921 (65%)
    INF:ubase:GPTP_SMALL_ALLOC: fragsize=4 fragused/fragnum=13/71 (18%)
    INF:ubase:SM_DATA_INST: fragsize=8 fragused/fragnum=1100/2002 (54%)
    INF:gptp:gptpman_run:GPTPNET_INTERVAL_TIMEOUT_NSEC=125000000
    INF:gptp:000000-634585:domainIndex=0, GM changed old=00:00:00:00:00:00:00:00, new=70:FF:76:FF:FE:1D:EC:F2
    INF:gptp:gptpclock_set_gmsync:gptpInstanceIndex=0, domainIndex=0, gmstate=2
    INF:gptp:set_phase_offsetGM:domainIndex=0, New adjustment(New GM?)
    Cpsw_handleLinkUp: Port 1: Link up: 1-Gbps Full-Duplex
    MAC Port 1: link up
    INF:cbase:cbl_query_response:tilld0: link UP, speed=1000, duplex=1 !!!!
    INF:gptp:index=1 speed=1000, duplex=full, ptpdev=tilld0
    WRN:gptp:computePropTime: computed PropTime is out of range = -76823, set 0
    WRN:gptp:000003-888571:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    INF:gptp:waiting_for_pdelay_interval_timer_proc:portIndex=1, not asCapable
    INF:gptp:md_pdelay_resp_sm_recv_req:port=1, set receivedNonCMLDSPdelayReq=1
    WRN:gptp:computePropTime: computed PropTime is out of range = -74124, set 0
    WRN:gptp:000005-007348:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
          5.451s : CPU load =  13.87 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -90940, set 0
    WRN:gptp:000006-007365:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -207265, set 0
    WRN:gptp:000007-007450:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -144291, set 0
    WRN:gptp:000008-007439:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -116153, set 0
    WRN:gptp:000009-007437:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -139294, set 0
    WRN:gptp:000010-007446:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    domain=0, offset=0nsec, hw-adjrate=0ppb
            gmsync=true, last_setts64=0nsec
         10.452s : CPU load =   5.52 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -54375, set 0
    WRN:gptp:000011-007354:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -69541, set 0
    WRN:gptp:000012-007403:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -111193, set 0
    WRN:gptp:000013-007442:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -154018, set 0
    WRN:gptp:000014-007444:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -82190, set 0
    WRN:gptp:000015-007354:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         15.453s : CPU load =   5.56 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -75727, set 0
    WRN:gptp:000016-007351:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -144521, set 0
    WRN:gptp:000017-007437:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -61644, set 0
    WRN:gptp:000018-007352:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -117114, set 0
    WRN:gptp:000019-007434:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -146054, set 0
    WRN:gptp:000020-007427:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         20.454s : CPU load =   5.62 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -111961, set 0
    WRN:gptp:000021-007429:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -80059, set 0
    WRN:gptp:000022-007383:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -98821, set 0
    WRN:gptp:000023-007353:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -100030, set 0
    WRN:gptp:000024-007436:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -55034, set 0
    WRN:gptp:000025-007349:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         25.455s : CPU load =   5.51 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -53868, set 0
    WRN:gptp:000026-007340:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -102164, set 0
    WRN:gptp:000027-007446:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -100148, set 0
    WRN:gptp:000028-007429:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -93991, set 0
    WRN:gptp:000029-007353:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -93441, set 0
    WRN:gptp:000030-007350:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         30.456s : CPU load =   5.63 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -92195, set 0
    WRN:gptp:000031-007354:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -84352, set 0
    WRN:gptp:000032-007351:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -74759, set 0
    WRN:gptp:000033-007353:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -75442, set 0
    WRN:gptp:000034-007356:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -86302, set 0
    WRN:gptp:000035-007352:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         35.457s : CPU load =   5.52 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -143872, set 0
    WRN:gptp:000036-007435:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -46218, set 0
    WRN:gptp:000037-007352:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -160472, set 0
    WRN:gptp:000038-007437:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -200865, set 0
    WRN:gptp:000039-007459:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -189551, set 0
    WRN:gptp:000040-007437:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         40.458s : CPU load =   5.70 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -104927, set 0
    WRN:gptp:000041-007436:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -148350, set 0
    WRN:gptp:000042-007435:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -78298, set 0
    WRN:gptp:000043-007344:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -108689, set 0
    WRN:gptp:000044-007434:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -142318, set 0
    WRN:gptp:000045-007465:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         45.459s : CPU load =   5.54 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -149643, set 0
    WRN:gptp:000046-007442:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -139843, set 0
    WRN:gptp:000047-007432:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -159335, set 0
    WRN:gptp:000048-007431:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -136003, set 0
    WRN:gptp:000049-007436:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -195768, set 0
    WRN:gptp:000050-007445:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         50.460s : CPU load =   5.60 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -167375, set 0
    WRN:gptp:000051-007439:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -158842, set 0
    WRN:gptp:000052-007449:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -189166, set 0
    WRN:gptp:000053-007432:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -156224, set 0
    WRN:gptp:000054-007438:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -182336, set 0
    WRN:gptp:000055-007437:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         55.461s : CPU load =   5.49 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -153749, set 0
    WRN:gptp:000056-007428:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -137086, set 0
    WRN:gptp:000057-007434:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -148786, set 0
    WRN:gptp:000058-007443:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -144164, set 0
    WRN:gptp:000059-007443:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -75115, set 0
    WRN:gptp:000060-007347:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         60.462s : CPU load =   5.73 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -71477, set 0
    WRN:gptp:000061-007356:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -78965, set 0
    WRN:gptp:000062-007348:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -77948, set 0
    WRN:gptp:000063-007356:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -76573, set 0
    WRN:gptp:000064-007346:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    Comparing your log file and mine, we can see that on your log file neighborPropDelay is equal to 1000 where on mine neighborPropDelay is always equal to 0.
    Let me answer your questions:
    1) here is the config file I am using on my Linux machine:
    # 802.1AS example configuration containing those attributes which
    # differ from the defaults.  See the file, default.cfg, for the
    # complete list of available options.
    [global]
    gmCapable		1
    priority1		100
    priority2		248
    logAnnounceInterval	0
    logSyncInterval		-3
    syncReceiptTimeout	3
    neighborPropDelayThresh	10000
    min_neighbor_prop_delay	-20000000
    assume_two_step		1
    path_trace_enabled	1
    follow_up_info		1
    transportSpecific	0x1
    ptp_dst_mac		01:80:C2:00:00:0E
    network_transport	L2
    delay_mechanism		P2P
    2) No switch ethernet is used, board and PC are directly connected via RJ45 cable
    3) I am using industrial PHY
    4) Here are step by step what I am doing:
    a) While EVM power OFF, I am runing below command on my Lunix machine :
         sudo ptp4l -i enp0s31f6 -m -l 6 -q -f ~/ptp_config.cfg
    b) Power ON the EVM then on CCS,under Target Configuration, I lauch selected configuration, then connect target, make a CPU reset, load the "gptp_app_awr2544-evm_r5fss0-0_freertos_ti-arm-clang.out" program.
    c) I open a serial terminal
    d) Click on "resume " in CCS and observe debug messages in the serial terminal window.
    Thanks.
    Jean-François
  • Hi Jean,
    My colleague is out of office and will get back to you next week.
    Ajay
  • Hi Ajay,
    Thanks for the info, still looking forward to solve this issue ;)
    Jean-François
  • Hi Jean,
    Apologies for the delay. Can you capture the ptp logs in the Wireshark while you are running this example. I'm sharing a capture file here for your reference. The main intent here is to see whether the ptp messages are getting exchanged between the pc and evm or not.
    /cfs-file/__key/communityserver-discussions-components-files/1023/gptp_5F00_example_5F00_capture.pcapng
    Shruti
  • Hi Shruti,
    Thank you, please find a pcap recording at this link:
    drive.google.com/.../view
    We see ptp messages exchanged between PC and evm.
    I observe the same behavior on the debug console:
              gPTP App
    Init all configs
    PHY 0 is alive
    unibase-1.1.4
    Start: uniconf_task
    INF:uconf:000000-275782:uniconf_main:uniconf started
    Start: gptp2d_task
    INF:gptp:000000-634593:domainIndex=0, GM changed old=00:00:00:00:00:00:00:00, new=70:FF:76:FF:FE:1D:EC:F2
    MAC Port 1: link up
    WRN:gptp:computePropTime: computed PropTime is out of range = -100729, set 0
    WRN:gptp:000003-763562:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -55330, set 0
    WRN:gptp:000004-882433:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
          5.452s : CPU load =  13.87 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -112237, set 0
    WRN:gptp:000005-882509:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -79920, set 0
    WRN:gptp:000006-882431:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -92433, set 0
    WRN:gptp:000007-882431:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -75005, set 0
    WRN:gptp:000008-882421:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -33127, set 0
    WRN:gptp:000009-882415:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         10.453s : CPU load =   5.30 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -49700, set 0
    WRN:gptp:000010-882418:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -27239, set 0
    WRN:gptp:000011-882399:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -64264, set 0
    WRN:gptp:000012-882410:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -60920, set 0
    WRN:gptp:000013-882424:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -82393, set 0
    WRN:gptp:000014-882412:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         15.454s : CPU load =   5.53 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -38414, set 0
    WRN:gptp:000015-882410:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -81188, set 0
    WRN:gptp:000016-882420:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -97036, set 0
    WRN:gptp:000017-882425:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:000018-882424:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -57629, set 0
    WRN:gptp:000019-882427:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         20.455s : CPU load =   5.64 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -34515, set 0
    WRN:gptp:000020-882410:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -57656, set 0
    WRN:gptp:000021-882420:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -97347, set 0
    WRN:gptp:000022-882415:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -80967, set 0
    WRN:gptp:000023-882417:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -28408, set 0
    WRN:gptp:000024-882410:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         25.456s : CPU load =   5.43 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -38246, set 0
    WRN:gptp:000025-882414:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -61701, set 0
    WRN:gptp:000026-882421:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -19653, set 0
    WRN:gptp:000027-882404:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -84503, set 0
    WRN:gptp:000028-882420:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -74413, set 0
    WRN:gptp:000029-882417:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         30.457s : CPU load =   5.66 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -104967, set 0
    WRN:gptp:000030-882494:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -63461, set 0
    WRN:gptp:000031-882422:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -68728, set 0
    WRN:gptp:000032-882414:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -84015, set 0
    WRN:gptp:000033-882418:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -80506, set 0
    WRN:gptp:000034-882418:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         35.458s : CPU load =   5.51 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -91000, set 0
    WRN:gptp:000035-882421:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -89794, set 0
    WRN:gptp:000036-882416:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -87629, set 0
    WRN:gptp:000037-882426:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -83768, set 0
    WRN:gptp:000038-882430:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -74960, set 0
    WRN:gptp:000039-882929:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         40.459s : CPU load =   5.53 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -54939, set 0
    WRN:gptp:000040-882439:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -53164, set 0
    WRN:gptp:000041-882429:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -51926, set 0
    WRN:gptp:000042-882439:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -102149, set 0
    WRN:gptp:000043-882512:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -86497, set 0
    WRN:gptp:000044-882444:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         45.460s : CPU load =   5.47 %
    Jean-François
  • Hi Jean,
    I'm not able to access your capture file, can you please share it again without putting it into drive, like I shared in the previous response.
    Shruti
  •  Hi Shruti,
    I tried to upload the file but it doesn't work .. I tried several times with different browser, but it doesn't want to work.
    Do you have any suggestion to share a pcap file ?
    I leave below a screenshot of some captured packets..
  • Hi Jean,
    you can use the insert option, it will allow you to upload the file. if that is not working then try to share the zip file.
    Shruti
  • ptp_testing.zip
    Hi Shruti,
    Thanks for the tip! Converting it in zip works.
    Attach is the pcap file.
    Jean-François
  • Hi Jean,
    Can you try the following things on your side -
    1. Try increasing the neighborPropDelayThresh value to 50000
    2. Share your PC ethernet card details using the follwoing command -
         lspci | awk '/[Nn]et/ {print $1}' | xargs -i% lspci -ks %
    Shruti
  • Hi Shruti,
    Increasing neighborPropDelayThresh to 50000 didn't changed
              gPTP App
    Init all configs
    PHY 0 is alive
    unibase-1.1.4
    Start: uniconf_task
    INF:uconf:000000-275793:uniconf_main:uniconf started
    Start: gptp2d_task
    INF:gptp:000000-634577:domainIndex=0, GM changed old=00:00:00:00:00:00:00:00, new=70:FF:76:FF:FE:1D:EC:F2
    MAC Port 1: link up
    WRN:gptp:computePropTime: computed PropTime is out of range = -71482, set 0
    WRN:gptp:000004-388643:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
          5.452s : CPU load =  13.38 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -68283, set 0
    WRN:gptp:000005-507364:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -81049, set 0
    WRN:gptp:000006-507365:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -78710, set 0
    WRN:gptp:000007-507357:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -76999, set 0
    WRN:gptp:000008-507360:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -97028, set 0
    WRN:gptp:000009-507346:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         10.453s : CPU load =   5.45 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -78777, set 0
    WRN:gptp:000010-507351:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -79769, set 0
    WRN:gptp:000011-507346:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -75235, set 0
    WRN:gptp:000012-507409:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -79798, set 0
    WRN:gptp:000013-507351:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -56353, set 0
    WRN:gptp:000014-507349:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         15.454s : CPU load =   5.51 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -58661, set 0
    WRN:gptp:000015-507350:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -47971, set 0
    WRN:gptp:000016-509353:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -98175, set 0
    WRN:gptp:000017-507351:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -82050, set 0
    WRN:gptp:000018-507343:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -84154, set 0
    WRN:gptp:000019-507343:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         20.455s : CPU load =   5.60 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -80023, set 0
    WRN:gptp:000020-507348:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -115976, set 0
    WRN:gptp:000021-507437:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -52838, set 0
    WRN:gptp:000022-507382:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -68088, set 0
    WRN:gptp:000023-507350:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -104813, set 0
    WRN:gptp:000024-507426:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         25.456s : CPU load =   5.50 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -96947, set 0
    WRN:gptp:000025-507356:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -86940, set 0
    WRN:gptp:000026-507353:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -94123, set 0
    WRN:gptp:000027-507347:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -58810, set 0
    WRN:gptp:000028-507346:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -101186, set 0
    WRN:gptp:000029-507436:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -101134, set 0
    WRN:gptp:000030-507433:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -84713, set 0
    WRN:gptp:000031-507353:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -70085, set 0
    WRN:gptp:000032-507346:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -101904, set 0
    WRN:gptp:000033-507426:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -103241, set 0
    WRN:gptp:000034-507434:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         35.458s : CPU load =   5.48 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -108654, set 0
    WRN:gptp:000035-507427:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -83748, set 0
    WRN:gptp:000036-507347:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -90137, set 0
    WRN:gptp:000037-507348:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -91356, set 0
    WRN:gptp:000038-507349:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -85411, set 0
    WRN:gptp:000039-507352:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         40.459s : CPU load =   5.65 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -104561, set 0
    WRN:gptp:000040-507425:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -91313, set 0
    WRN:gptp:000041-507338:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -115208, set 0
    WRN:gptp:000042-507436:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -48786, set 0
    WRN:gptp:000043-507337:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -117042, set 0
    WRN:gptp:000044-507429:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         45.460s : CPU load =   5.52 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -77380, set 0
    WRN:gptp:000045-507349:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -81947, set 0
    WRN:gptp:000046-507337:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -67029, set 0
    WRN:gptp:000047-507344:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -90785, set 0
    WRN:gptp:000048-507338:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -106449, set 0
    WRN:gptp:000049-507429:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         50.461s : CPU load =   5.69 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -109383, set 0
    WRN:gptp:000050-507432:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -105225, set 0
    WRN:gptp:000051-507429:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -82624, set 0
    WRN:gptp:000052-507334:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -99057, set 0
    WRN:gptp:000053-507344:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -112891, set 0
    WRN:gptp:000054-507425:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         55.462s : CPU load =   5.51 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -97110, set 0
    WRN:gptp:000055-507353:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -79805, set 0
    WRN:gptp:000056-507348:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -103488, set 0
    WRN:gptp:000057-507425:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -111164, set 0
    WRN:gptp:000058-507431:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -81560, set 0
    WRN:gptp:000059-507344:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         60.463s : CPU load =   5.69 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -54100, set 0
    WRN:gptp:000060-507346:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -64401, set 0
    WRN:gptp:000061-507351:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -88150, set 0
    WRN:gptp:000062-507346:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -92294, set 0
    WRN:gptp:000063-507353:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -80270, set 0
    WRN:gptp:000064-507334:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         65.464s : CPU load =   5.54 %
    WRN:gptp
    Here is my PC ethernet card details:
    jeff@jeff-laptop:~$ lspci | awk '/[Nn]et/ {print $1}' | xargs -i% lspci -ks %
    00:14.3 Network controller: Intel Corporation Device 7e40 (rev 20)
    Subsystem: Intel Corporation Device 0090
    Kernel driver in use: iwlwifi
    Kernel modules: iwlwifi
    00:1f.6 Ethernet controller: Intel Corporation Device 550b (rev 20)
    Subsystem: Lenovo Device 50e9
    Kernel driver in use: e1000e
    Kernel modules: e1000e
    Thanks .
    regards,
    Jean-François
  • Hi Jean,
    Thanks for sharing the required details. I want you to do a little modification in the code and provide us the logs for further debugging.
    Please do the following modifications in the SDK file mcu_plus_sdk_awr2544_09_01_00_05\examples\networking\tsn\tsninit.c"
    1. modify "init_para.ub_log_initstr="4,ubase:45,cbase:45,uconf:45,gptp:55,lldp:45";" to "init_para.ub_log_initstr="4,ubase:45,cbase:45,uconf:45,gptp:77,lldp:45";
    2. rebuild the gptp example.
    Once you are done with the above modification, share the logs here.
    Shruti
  • Hi Shruti,
    I made the requested changes:
    And below are logs and pcap.
    20241112_gptp_pcap.zip
              gPTP App
    Init all configs
    PHY 0 is alive
    unibase-1.1.4
    Start: uniconf_task
    INF:uconf:000000-275758:uniconf_main:uniconf started
    Start: gptp2d_task
    MAC Port 1: link up
    WRN:gptp:computePropTime: computed PropTime is out of range = -56141, set 0
    WRN:gptp:000003-763492:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -173217, set 0
    WRN:gptp:000004-882519:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
          5.452s : CPU load =  13.88 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -118966, set 0
    WRN:gptp:000005-882512:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -51128, set 0
    WRN:gptp:000006-882440:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -114975, set 0
    WRN:gptp:000007-882505:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -109208, set 0
    WRN:gptp:000008-882513:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -97078, set 0
    WRN:gptp:000009-882428:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         10.453s : CPU load =   5.34 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -100877, set 0
    WRN:gptp:000010-882514:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -41132, set 0
    WRN:gptp:000011-884973:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -119137, set 0
    WRN:gptp:000012-882507:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -50730, set 0
    WRN:gptp:000013-882436:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -64103, set 0
    WRN:gptp:000014-882438:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         15.454s : CPU load =   5.49 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -87272, set 0
    WRN:gptp:000015-882423:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -56478, set 0
    WRN:gptp:000016-882431:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -42976, set 0
    WRN:gptp:000017-882434:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -87606, set 0
    WRN:gptp:000018-882438:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -31367, set 0
    WRN:gptp:000019-882410:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         20.455s : CPU load =   5.65 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -100972, set 0
    WRN:gptp:000020-882514:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -102560, set 0
    WRN:gptp:000021-882505:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -93239, set 0
    WRN:gptp:000022-882425:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -102308, set 0
    WRN:gptp:000023-882510:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -117542, set 0
    WRN:gptp:000024-882507:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         25.456s : CPU load =   5.56 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -75062, set 0
    WRN:gptp:000025-882432:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -77259, set 0
    WRN:gptp:000026-882428:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -113864, set 0
    WRN:gptp:000027-882511:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -98916, set 0
    WRN:gptp:000028-882423:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -94161, set 0
    WRN:gptp:000029-882434:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         30.457s : CPU load =   5.65 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -114236, set 0
    WRN:gptp:000030-882516:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -122159, set 0
    WRN:gptp:000031-882519:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -110568, set 0
    WRN:gptp:000032-882507:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -101218, set 0
    WRN:gptp:000033-882516:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -109056, set 0
    WRN:gptp:000034-882514:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         35.458s : CPU load =   5.53 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -114714, set 0
    WRN:gptp:000035-882505:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -97697, set 0
    WRN:gptp:000036-882429:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -84883, set 0
    WRN:gptp:000037-882438:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -93671, set 0
    WRN:gptp:000038-882426:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -73958, set 0
    WRN:gptp:000039-882450:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         40.459s : CPU load =   5.61 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -66917, set 0
    WRN:gptp:000040-882440:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -73199, set 0
    WRN:gptp:000041-882452:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -76386, set 0
    WRN:gptp:000042-882424:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -115246, set 0
    WRN:gptp:000043-882501:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -97850, set 0
    WRN:gptp:000044-882429:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         45.460s : CPU load =   5.53 %
         50.461s : CPU load =   2.24 %
         55.462s : CPU load =   2.07 %
         60.463s : CPU load =   2.18 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -34217, set 0
    WRN:gptp:000061-882421:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -13423, set 0
    WRN:gptp:000062-882728:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -109909, set 0
    WRN:gptp:000063-883020:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -658032, set 0
    WRN:gptp:000064-884570:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
         65.464s : CPU load =   4.47 %
    WRN:gptp:computePropTime: computed PropTime is out of range = -114828, set 0
    WRN:gptp:000065-883224:waiting_for_pdelay_interval_timer_proc:portIndex=1, sourcePortIdentity=C4:C6:E6:FF:FE:C8:A6:55, thisClock=70:FF:76:FF:FE:1D:EC:F2, neighborPropDelay=0
    WRN:gptp:computePropTime: computed PropTime is out of range = -10560, set 0
    WRN
    I am not sure to see any changes ..
    Thanks and regards,
    Jean-François
  • Hi Shruti,
    Would you have any updates regarding this topic please?
    Many thanks.
    Jean-François
  • Hi Jean,
    Apologies for the delay. We have checked your logs, and it seems correct only.
    Can you perform one more experiment for further debugging, since it is working on our end. Can you try connecting 2 EVM's and run the same example? make sure that both the EVM's should have a different MAC address. You can configure that in syscfg tool.
    Let me know if this works for you.
    Shruti
  • Hi Shruti,
    Quick question: By "We have checked your logs, and it seems correct only.", are you suggesting that finally the gPTP demo is working on my side and that clock are between master and slave are well synchronized?
    Yes, at the moment my company purchased only 1 EVM. I will try to with a raspberry pi instead of my PC just in case.
    Thank you.
    Jean-François
  • Hi Jean,
    From the logs, it is clear that the PTP messages have been exchanged properly. Still, to make sure it's not the application fault, we want to perform the experiment with 2 EVM's.
    Please try the same and let me know if that works.
    Shruti
  • Hi Shruti,
    Thanks for the feedback. I will try it as soon I get a second AWR2544 evm !
    Jean-François
