IWRL6432BOOST: Control Initialization / Factory Calibration Failed
Part Number: IWRL6432BOOST
Other Parts Discussed in Thread: MMWAVE-L-SDK
Hi there,
I'm trying to use the IWRL6432BOOST EVM, running the Level Sensing example from Radar Toolbox v2.20.00.05. I'm having a similar problem as described in this related thread, but it is locked and no answer was presented: https://e2e.ti.com/support/sensors-group/sensors/f/sensors-forum/1281288/iwrl6432boost-mmwave-control-initialization-failed
I'm getting this error on call to sensorStart after loading the attached config:
Error: mmWave Control Initialization failed [Error code -205787070] [errorLevel 2] [mmWaveErrorCode -3141] [subsysErrorCode 15376]
Error: Factory Calibration failure
Error: mmWave factory calibration failed
Error: mmWave Open failed [Error code: -3121 Subsystem: 15346]
Error -1
I've tried loading the ATE calibration firmware image in the MMWAVE-L-SDK, version 05.03.00.02 (14 Jul 2023), and letting it run in functional mode for a few minutes, but that didn't seem to make a difference.
Any help would be appreciated. Thanks!
0636.high_accuracy_demo_xwrl64xx.cfg
