AWR2243: AWR2243 Cascade Radar: Error while creating the bootable SD card to get the Point Cloud Data (PCD) directly from the Cascade radar + DSP board
Part Number: AWR2243
Other Parts Discussed in Thread: MMWCAS-DSP-EVM,
Hello, we are using AWR2243 Cascade radar (MMWAVECAS-RF-EVM) board with MMWCAS-DSP-EVM to collect the point cloud data i.e, after the processing of raw data using the DSP board.
We tried to use the PROCESSOR_SDK_VISION_03_08_00_00 to create the SD card boot and followed the procedure given in "VisionSDK_Linux_UserGuide.pdf". While running the "make -s" command, we incur the following error:
Can you please help us in getting rid of this error?
# Configuro done!
# Making tda2xx-evm:ipu1_1:release:vision_sdk_lib...
# Compiling tda2xx-evm:ipu1_1:release:vision_sdk: /home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/apps/src/common/app_init/app_init_ipu1_1.c
# Compiling generated MAIN_APP_ipu1_1_pem4.oem4
# Linking into /home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_ipu1_1_release.xem4...
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 227: warning:
   memory range not found: IPU1_1_DATA_MEM on page 0
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 227: error:
   no valid memory range(null) available for placement of "GROUP_1"
   program will not fit into available memory.  run placement with alignment
   fails for section "GROUP_1" size 0x1b5110
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 255: warning:
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 255: error:
   ".bss:taskStackSection"
   fails for section ".bss:taskStackSection" size 0x1ae000
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 237: warning:
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 237: error:
   no valid memory range(null) available for placement of ".data"
   fails for section ".data" size 0x31076
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 225: warning:
   memory range not found: IPU1_1_CODE_MEM on page 0
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 225: error:
   no valid memory range(null) available for placement of ".text"
   program will not fit into available memory.  placement with alignment fails
   for section ".text" size 0x30dfb
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 236: warning:
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 236: error:
   no valid memory range(null) available for placement of ".const"
   for section ".const" size 0x8a98
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 226: warning:
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 226: error:
   no valid memory range(null) available for placement of ".stack"
   fails for section ".stack" size 0x4000
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 242: warning:
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 242: error:
   no valid memory range(null) available for placement of ".args"
   for section ".args" size 0x64
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 233: warning:
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 233: error:
   fails for section ".binit" size 0x0
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 235: warning:
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 235: error:
   fails for section ".init_array" size 0x0
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 238: warning:
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 238: error:
   fails for section ".fardata" size 0x0
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 239: warning:
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 239: error:
   fails for section ".switch" size 0x0
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 240: warning:
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 240: error:
   fails for section ".sysmem" size 0x0
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 241: warning:
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 241: error:
   fails for section ".far" size 0x0
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 243: warning:
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 243: error:
   fails for section ".cio" size 0x0
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 244: warning:
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 244: error:
   fails for section ".ARM.exidx" size 0x0
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 245: warning:
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 245: error:
   fails for section ".ARM.extab" size 0x0
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 254: warning:
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 254: error:
   fails for section ".plt" size 0x0
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 260: warning:
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 260: error:
   for section "xdc.meta" size 0x152
error: program will not fit into available memory.  run placement with
   alignment fails for section ".TI.persistent" size 0x0
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 234: warning:
"/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 234: error:
   no valid memory range(null) available for placement of ".cinit"
   for section ".cinit" size 0x2072
 undefined                                   first referenced
  symbol                                         in file
 IpcMgr_rpmsgStartup                         /home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/lib/tda2xx-evm/ipu1_1/release/links_common_system.aem4<system_rpmsg.oem4>
 NameMap_register                            /home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/lib/tda2xx-evm/ipu1_1/release/links_common_system.aem4<system_rpmsg.oem4>
 NameMap_unregister                          /home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/lib/tda2xx-evm/ipu1_1/release/links_common_system.aem4<system_rpmsg.oem4>
 RPMessage_create                            /home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/lib/tda2xx-evm/ipu1_1/release/links_common_system.aem4<system_rpmsg.oem4>
 RPMessage_delete                            /home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/lib/tda2xx-evm/ipu1_1/release/links_common_system.aem4<system_rpmsg.oem4>
 RPMessage_send                              /home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/lib/tda2xx-evm/ipu1_1/release/links_common_system.aem4<system_rpmsg.oem4>
 ti_ipc_remoteproc_Resource_getVdevStatus__E /home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/lib/tda2xx-evm/ipu1_1/release/links_common_system.aem4<system_rpmsg.oem4>
error: unresolved symbols remain
../../master/ELFLNK/build.c:2612:internal fatal error #10251:
   ("xdc.meta:MAIN_APP_ipu1_1_pem4.oem4")
INTERNAL ERROR: /home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/ti_components/cg_tools/linux/ti-cgt-arm_16.9.2.LTS/bin/armlnk had an internal inconsistency and aborted
This is caused by a defect in the compiler itself. TI Customer
Support may be able to suggest a workaround to avoid this.
Upgrading to the newest version of the compiler may fix this problem.
Contact TI in the E2E support forums at http://e2e.ti.com under
"Development Tools", "TI C/C++ Compiler". See the link titled
"Submitting an issue". Include this ENTIRE error message and a
copy of the .pp file created when option --preproc_with_comment
(-ppc) is used.
make[7]: *** [/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/build/rtos/makerules/rules_m4.mk:315: /home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_ipu1_1_release.xem4] Error 2
make[6]: *** [/home/jayanth_s/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/build/rtos/makerules/common.mk:272: ipu1_1] Error 2
make[5]: *** [MAKEFILE.MK:106: apps_ipu1_1] Error 2
make[4]: *** [MAKEFILE.MK:31: apps] Error 2
make[3]: *** [MAKEFILE.MK:315: apps] Error 2
make[2]: *** [Makefile:175: apps_exe] Error 2
make[1]: *** [Makefile:42: apps] Error 2
make: *** [Makefile:12: vision_sdk] Error 2
