TMCS1126-Q1: Connecting Voc pin to ground
Part Number: TMCS1126-Q1
We are using TMCS1126C5BQDVGR hall effect sensor in our battery charging control module .We are not using Voc & oc pin. In datasheet it is recommended oc pin to  GND & Voc pin to Vs if not used. But our Supplier grounded both pins . If we tie, the voc pin to ground and operate for longer hours will it damage the IC? We are experiencing some issues in current sensor while operating long hours. So need to make sure connecting Vs pin to ground will cause any issue.
