Part Number: LDC5072-Q1
We have successfully interfaced the LDC5072-Q1 inductive position sensor with the metallic (Aluminium) target and as suggested by the
In LDC5072_Sensor_Designer software, we followed the steps to get proper sinusoidal sin/cos output.
However, we faced an offset issue in SIN/COS output (Amplitude difference). We tried Automatic Gain Control and Manual Gain Control by adjusting the voltage across the AGC_EN pin through the resistor divider.
However, the results are the same. I've attached the schematic of the actual hardware and the results for your reference. As you can see in the results image the phase difference between SIN/COS is correct but the amplitude of both outputs is different and it varies with the Air gap between the sensor and target. (Yellow is SIN+ and Blue is COS+ with respect to Ground).
Please suggest or guide us to overcome this issue.
Thanks and regards
Prasanna Pandit
Aproposdrive, Pune.
