AWR2944EVM: Why is the Enet so fragile?
Part Number: AWR2944EVM
Hi Designer,
I encounter a problem when transferring pointCloud data through Enet in DDMA mode.
1.when size of data transferred to PC excesses TCP_MSS(1460B) defined in <lwipopt.h>, netconn_write will result in crush on the board.
2.I try to divide data into segments manually to bypass this problem, it will crush as well if there is not a break of 50ms at least  between transfers.
Zisheng Wang.
