AWR2243BOOST: ADC output is too big
Part Number: AWR2243BOOST
Other Parts Discussed in Thread: AWR2243, , DCA1000EVM
Hello experts,
I am testing awr2243. the hardware is AWR2243Boost and DCA1000EVM.the config file of 2243 is attached.
the adc output is about +/- 200 with tx is disabled and rx gain is 48.
is the value normal in your experence? how can i decrease the value to lower than +/- 20 with the same conditions?
#For detailed view of mmWave Radar configuration structure
#please refer
#ti\control\mmwavelink\docs\doxygen\html\index.html
#Global configuration
#Firmware download enable/disable; 1 - Enable; 0 - Disable
#mmWaveLink logging enable/disable; 1 - Enable; 0 - Disable
#Transport mode; 1 - I2C; 0 - SPI
#Flash connected enable/disable; 1 - Enable; 0 - Disable
EnableFwDownload=1;
EnableMmwlLogging=0;
TransferMode=0;
IsFlashConnected=1;
#END
#power on master arguments, please modify if needed.
#rlClientCbs_t: crcType 0:16Bit/1:32Bit/2:64Bit,
# ackTimeout: This timeout value can vary on different PC, user needs to recalibrate
#  this value based on the system where this application runs. Ideally ackTimeout
#  should be in range of ~5mSec
crcType=1;
ackTimeout=50000;
#END
#channel config parameters, please modify if needed.
#rlChanCfg_t
channelTx=1;
channelRx=3;
cascading=0;
#END
#ADC out config parameters, please modify if needed.
#rlAdcOutCfg_t
adcBits=2;
adcFormat=1;
#END
#DATA format config parameters, please modify if needed.
#rlDevDataFmtCfg_t
rxChanEn=3;
adcBitsD=2;
adcFmt=1;
iqSwapSel=0;
chInterleave=0;
#END
#Low power config Paramters, please modify if needed.
#rlLowPowerModeCfg_t
anaCfg=0;
lpAdcMode=0;
#END
#Data Path config parameters, please modify if needed
#rlDevDataPathCfg_t
intfSel=1;
transferFmtPkt0=1;
transferFmtPkt1=0;
cqConfig=2;
cq0TransSize=64;
cq1TransSize=64;
cq2TransSize=64;
#END
#LVDS clock config parameters, please modify if needed
#rlDevDataPathClkCfg_t
laneClk=1;
dataRate=1;
#END
#SET HSI clock parameters, please modify if needed.
#rlDevHsiClk_t
hsiClk=9
#END
#LANE config parameters, please modify if needed.
#rlDevLaneEnable_t
laneEn=3;
#END
#LVDS Lane Config parameters, please modify if needed.
#rlDevLvdsLaneCfg_t
laneFmtMap=0;
laneParamCfg=1;
#END
#Programmable Filter config parameters, please modify if needed.
#rlRfProgFiltConf_t
profileId=0;
coeffStartIdx=0;
progFiltLen=14;
progFiltFreqShift=100;
#END
#Profile config parameters, please modify if needed.
#rlProfileCfg_t
profileId=0;
pfVcoSelect=2;
startFreqConst=1471594320;
idleTimeConst=200;
adcStartTimeConst=300;
rampEndTime=4500;
txOutPowerBackoffCode=0;
txPhaseShifter=0;
freqSlopeConst=52;
txStartTime=0;
numAdcSamples=800;
digOutSampleRate=22500;
hpfCornerFreq1=0;
hpfCornerFreq2=0;
rxGain=176;#176(36db+48db)
#END
#Chirp Configuration parameters, please modify if needed.
#rlChirpCfg_t
chirpStartIdx=0;
chirpEndIdx=0;
profileIdCPCFG=0;
startFreqVar=0;
freqSlopeVar=0;
idleTimeVar=0;
adcStartTimeVar=0;
txEnable=0;
#END
#Frame configuration parameters, please modify if needed.
#rlFrameCfg_t
chirpStartIdxFCF=0;
chirpEndIdxFCF=0;
frameCount=16;
loopCount=160;
periodicity=4000000;
triggerDelay=0;
numAdcSamples=1600;
triggerSelect=1;
#END
