Other Parts Discussed in Thread: TDA2,
I am trying the tda2xx_cascade_linux_radar
under vision_sdk
, according to the VisionSDK_Linux_UserGuide.pdf.
/mnt
under vision_sdk
/mnt
Hi Lei,
Let me assign this E2E to the appropriate team.
Samhitha
Hello Lei,
Are you following any procedure to mount the SSD correctly to the TDA2 system?
Please see e2e.ti.com/.../5085488https://e2e.ti.com/support/sensors-group/sensors/f/sensors-forum/1333000/mmwcas-dsp-evm-mmwcas-dsp-evm/5085488#5085488
-Josue
Hi Josue,
Thank you very much for your response. I have followed the steps and successfully mounted /dev/nvme0n1p1 to /mnt/ssd, and I used cascade_radar_multi_datacollect USECASE to save the raw data. However, I would like to use PTP to synchronize the time between the MMWCAS-DSP-EVM and the other sensor. I noticed that /dev/ptp0 already exists in the Linux system on the MMWCAS-DSP-EVM, but I couldn’t find tools like ptp4l.Therefore, I need to compile linuxptp for the Linux system on the MMWCAS-DSP-EVM. How can I compile and install it on the MMWCAS-DSP-EVM's Linux?
Hi Josue,
I have obtained ptp4l
through cross-compilation, moved it to the MMWCAS-DSP-EVM, and the version is 1.92. Next, I plan to perform PTP time synchronization with the host. What I want to know is whether I can assign a new timestamp to the raw data by modifying the following time retrieval API?
Hello Lei,
I am glad that you got this to work. In general, for this forum to be easy to use, please post a new question or related question once the primary question has been answered: .
I will be closing this one since the original question has been answered and resolved.
Josue
