Hello, team
I want to know recommended PCB board pattern at the part connected to the IC .
Could you provide information related with the recommend PCB board pattern?
Hello, team
Hi Yuichi,
NSMD is preferred. Please refer to the package outline section in the datasheet about the solder mask opening parameters. Hope this answers your question.
Aydin
Hello, Aydin
Thank you for reply.
What I want to know is the pattern at the part of launch.
At the part of launch, through holes should be embedded with PCB .
So I want to know recommended PCB pattern that includes shape of launch.
Yuichi
Hi Yuichi,
Please download the design files from the product page if you haven't AWR2E44PEVM Evaluation board | TI.com
Once you open up the file in Altium, we have a dxf file already in the mechanical layer which you can enable to view and also use it in your design to define the cut-out portion. Please unable the fab notes and go over the notes starting from 17 regarding the cut-out area and the tolerance after plating.
Aydin
Hello, Aydin
I can check the pattern.
Thank you for your corporation.
Yuichi
