Hello there,
I'm using the TMP392 in a new design. To make sure the right resistor values are mounted, I'd like to test them after manufacturing in-circuit. The datasheet only refers to the in-system trip tests, which shows whether the sensor itself works properly.
So my plan would be to apply a voltage to the set resistors and measure the current. Could this plan work or are there any significant leakage currents into the sensor (besides the +-20 nA according to the datasheet) which would lead to wrong results?
Thank you very much
Mitja
