what is the accuracy of the LDC5072 over radial and axial displacement tolerance (i.e. ±0.5mm)?
Hello Simone,
Thanks for considering to use Texas Instruments. Figures 7-1 through 7-5 in our datasheet indicate what kind of angle error you might expect for different operating conditions. In that case, the error is provided in degrees. Assuming 1° error, we could then translate to mm dimensions for your system with x = radius*cos(radians(typ degree value±1°)) and y = radius*sin(radians(typ degree value±1°)).
I saw your message, will try to respond tomorrow morning after I discuss with our systems engineer.
