Hi Team,
i am currently working in with a System which uses multiple IWR6243 Cascaded Setups. The different CSI Signals run through multiplexers that switch between the Signals before they get to the processing unit. Is it possible to embed self defined Meta Data (for a example a self defined Chip ID) in the ADC Samples of each Frame / Chirp to get the processing unit to know which Sensor is currently transferring data. One Byte would be more than enough.
Tim
