AWR2E44PEVM: mmw demo cannot be executed
Part Number: AWR2E44PEVM
Dear team,
We could run the demo with "enet_cpsw_tcpserver" (EVM server, Static IP mode), but cannot run the demo of PC sever one by using "tcpserver.py".
First we run "tcpserver.py" on our PC. Next, we Flash the Enet version of mmw_ddm demo  to the EVM and execute command "enetStreamCfg 1 192.168.1.10". But it does not connect.
We are using below setting, would you please advise if you notice something to resolve this issue?
PC: 192.168.1.10
tcpserver.py: HOST =192.168.1.10, Port: 7
PHY: Industrial PHY
We are not using router and connecting directly PC and EVM.
YK
  • Hi Yuto,
    Can we check the default demo first if it is working or not. Please follow section 4.5 in the following document -
    mmwave_mcuplus_sdk_04_07_00_01/mmwave_mcuplus_sdk_04_07_00_01/docs/mmwave_mcuplus_sdk_user_guide.pdf
    Connect a router between the PC and EVM and follow the steps mentioned in the document. Let me know if it is working as expected or not.
    Shruti
  • Hi Shruti,
    We found it was caused by firewall on their PC and could resolve now. But the Ethernet output stops after 3 seconds. Is there limitation about it?
    YK
