AWR2243: MMWCAS-RF-EVM & MMWCAS-DSP-EVM
Part Number: AWR2243
Other Parts Discussed in Thread: MMWCAS-DSP-EVM, MMWCAS-RF-EVM
We are booting mmwcas-rf-evm,mmwcas-dsp-evm using mmwave_studio_cascade_user_guide. we ran lua scripts for use case-1 : test source and use case-2:mimo configuration. The 2nd use case ran successfully and the 1st use case failed in capturing the data.please find the logs below.
Use case-1
GM: Constructor
GM: Mon Feb 24 10:55:08 2025
RSTD.Transmit("/Settings")
[10:55:09]
[10:55:09] ### Running Startup script: "C:\ti\mmwave_studio_03_00_00_14\mmWaveStudio\Scripts\Startup.lua" ###
[10:55:09] RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
[10:55:09] RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
[10:55:09] Scripter ignored: Attempt to UnBuild() again or before Build.
[10:55:09] RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "C:\\ti\\mmwave_studio_03_00_00_14\\mmWaveStudio\\Clients\\\\LabClient.dll")
[10:55:09] RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
[10:55:09] RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
[10:55:09] RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
[10:55:09] RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
[10:55:09] RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
[10:55:09] RSTD.SetVar ("/Settings/AL Client/AL Dll" , "C:\\ti\\mmwave_studio_03_00_00_14\\mmWaveStudio\\RunTime\\SAL.dll")
[10:55:09] RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
[10:55:09] RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
[10:55:09] RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
[10:55:09] RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
[10:55:09] RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
[10:55:09] RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
[10:55:09] RSTD.Transmit("/")
[10:55:09] RSTD.SaveSettings(): Settings saved to "C:\Users\Admin\AppData\Roaming\RSTD\config.xml"
[10:55:09] RSTD.Build()
[10:55:09] RSTD.AL_Build()
[10:55:09] RSTD.AL_LoadXml()
[10:55:09] RSTD.AL_Init()
[10:55:09] RSTD.Clients_Build()
[10:55:09] GM: Init
[10:55:09] GM: Loaded 'C:\ti\mmwave_studio_03_00_00_14\mmWaveStudio\Clients\\LabClient.dll'
[10:55:09] GM: 1 Guest (s) init
[10:55:09] GM: 1 Module(s) init
[10:55:09] GM: 2 Tab (s) init
[10:55:09] RSTD.Client_LoadXml()
[10:55:10] [RadarAPI]: ar1.selectRadarMode(0)
[10:55:10] [RadarAPI]: Status: Passed
[10:55:10] Matlab Runtime Engine is installed
[10:55:10] [RadarAPI]: Starting Matlab Engine..
[10:55:18] [RadarAPI]: Matlab Engine Started!
[10:55:22] [RadarAPI]: ar1.selectCascadeMode(0)
[10:55:22] [RadarAPI]: Status: Passed
[10:55:22] [RadarAPI]: ar1.LoadSettings('C:\Users\Admin\AppData\Roaming\RSTD\ar1gui.ini')
[10:55:23] TESTING = false
[10:55:23] RstdNet: Port 2777: Listening..
[10:55:23]
[10:55:23] ***Script completed successfully.***
[10:55:30] [RadarAPI]: ar1.selectRadarMode(1)
[10:55:30] [RadarAPI]: ar1.selectCascadeMode(1)
[10:55:30] [RadarAPI]: Status: Passed
[10:55:31] [RadarAPI]: Status: Passed
[10:55:33] [RadarAPI]: ar1.SelectCaptureDevice("TDA2XX")
[10:55:33] [RadarAPI]: Status: Passed
[10:55:36] [RadarAPI]: TDAStatusCallback Event Registered
[10:55:36] [RadarAPI]: registerTDAStatusCallback Status: Passed
[10:55:36] [RadarAPI]: ar1.ConnectTDA("192.168.33.180", 5001, 15)
[10:55:37] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:55:37] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_VERSION_INFO Async event recieved() with status 0. TDA Version : REL_VISION_SDK_03_07_01_00 Aug 5 2019 15:04:45[10:55:37] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:55:39] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:55:39] [RadarAPI]: ConnectTDACaptureCard Status: Passed
[10:55:39] TDA Capture Card Status : CONNECTED!
[10:56:05] LuaLoad("C:/ti/mmwave_studio_03_00_00_14/mmWaveStudio/Scripts/Cascade/Cascade_Configuration_TestSource.lua")
[10:56:08] Setting up Studio for Cascade started..
[10:56:08] [RadarAPI]: Connection to the TDA is already established!
[10:56:08] ConnectTDA Successful
[10:56:08] selectCascadeMode Successful
[10:56:08] Setting up Studio for Cascade ended..
[10:56:08] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:56:09] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:56:09] [RadarAPI]: ar1.FullReset(1)
[10:56:09] [RadarAPI]: Status: Passed
[10:56:09] [RadarAPI]: ar1.SOPControl_mult(1,4)
[10:56:09] Master : SOP Reset Successful
[10:56:10] [RadarAPI]: ar1.PowerOn_mult(1, 0, 1000, 0,0)
[10:56:10] [RadarAPI]: Status: Passed
[10:56:10] [DeviceId-0] MSS power up done async event received!
[10:56:10] Master : SPI Connection Successful
[10:56:10] [RadarAPI]: ar1.DownloadBssFwOvSPI_mult(1, C:\\ti\\mmwave_dfp_02_02_02_01\\firmware\\xwr22xx_metaImage.bin)
[10:56:13] Master : FW Download Successful
[10:56:14] [RadarAPI]: ar1.SelectChipVersion("AR1243")
[10:56:14] [RadarAPI]: Status: Passed
[10:56:14] [RadarAPI]: ar1.deviceVariantSelection("XWR2243")
[10:56:14] [RadarAPI]: ar1.frequencyBandSelection("77G")
[10:56:14] [RadarAPI]: ar1.SelectChipVersion("XWR2243")
[10:56:14] Device Status : XWR2243/ASIL-B/SOP:4/ES:1.1
[10:56:14] [RadarAPI]: ar1.RfEnable_mult(1)
[10:56:15] [DeviceId-0] BSS power up done async event received!
[10:56:15] [RadarAPI]: Status: Passed
[10:56:16] Master : RF Power Up Successful
[10:56:16] [RadarAPI]: ar1.ChanNAdcConfig_mult(1, 1, 1, 1, 1, 1, 1, 1, 2, 1, 0, 1)
[10:56:17] [RadarAPI]: Status: Passed
[10:56:17] Master : Channel & ADC Configuration Successful
[10:56:17] [RadarAPI]: Device 2 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:56:17] [RadarAPI]: ar1.FullReset(2)
[10:56:17] [RadarAPI]: ar1.SOPControl_mult(2,4)
[10:56:17] Device 2 : SOP Reset Successful
[10:56:18] [DeviceId-1] MSS power up done async event received!
[10:56:18] [RadarAPI]: ar1.AddDevice(2)
[10:56:18] [RadarAPI]: Status: Passed
[10:56:18] Device 2 : SPI Connection Successful
[10:56:18] [RadarAPI]: Device 4 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:56:19] [RadarAPI]: ar1.FullReset(4)
[10:56:19] [RadarAPI]: Status: Passed
[10:56:19] [RadarAPI]: ar1.SOPControl_mult(4,4)
[10:56:19] Device 3 : SOP Reset Successful
[10:56:19] [DeviceId-2] MSS power up done async event received!
[10:56:19] [RadarAPI]: ar1.AddDevice(4)
[10:56:19] Device 3 : SPI Connection Successful
[10:56:19] [RadarAPI]: Device 8 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:56:20] [RadarAPI]: ar1.FullReset(8)
[10:56:20] [RadarAPI]: Status: Passed
[10:56:20] [RadarAPI]: ar1.SOPControl_mult(8,4)
[10:56:20] Device 4 : SOP Reset Successful
[10:56:20] [DeviceId-3] MSS power up done async event received!
[10:56:20] [RadarAPI]: ar1.AddDevice(8)
[10:56:20] Device 4 : SPI Connection Successful
[10:56:20] [RadarAPI]: ar1.DownloadBssFwOvSPI_mult(14, C:\\ti\\mmwave_dfp_02_02_02_01\\firmware\\xwr22xx_metaImage.bin)
[10:56:24] Slaves : FW Download Successful
[10:56:25] [RadarAPI]: ar1.SelectChipVersion("AR1243")
[10:56:25] [RadarAPI]: Status: Passed
[10:56:25] [RadarAPI]: ar1.SelectChipVersion("XWR2243")
[10:56:25] Slave1 Device Status : XWR2243/ASIL-B/SOP:4/ES:1.1
[10:56:26] [RadarAPI]: ar1.SelectChipVersion("AR1243")
[10:56:26] [RadarAPI]: Status: Passed
[10:56:26] [RadarAPI]: ar1.SelectChipVersion("XWR2243")
[10:56:26] Slave2 Device Status : XWR2243/ASIL-B/SOP:4/ES:1.1
[10:56:27] [RadarAPI]: ar1.SelectChipVersion("AR1243")
[10:56:27] [RadarAPI]: Status: Passed
[10:56:27] [RadarAPI]: ar1.SelectChipVersion("XWR2243")
[10:56:27] Slave3 Device Status : XWR2243/ASIL-B/SOP:4/ES:1.1
[10:56:27] [RadarAPI]: ar1.RfEnable_mult(14)
[10:56:27] [DeviceId-1] BSS power up done async event received!
[10:56:27] [DeviceId-2] BSS power up done async event received!
[10:56:27] [DeviceId-3] BSS power up done async event received!
[10:56:32] Slaves : RF Power Up Successful
[10:56:32] [RadarAPI]: ar1.ChanNAdcConfig_mult(14, 1, 1, 1, 1, 1, 1, 1, 2, 1, 0, 2)
[10:56:33] [RadarAPI]: Status: Passed
[10:56:33] Slaves : Channel & ADC Configuration Successful
[10:56:33] [RadarAPI]: ar1.RfLdoBypassConfig_mult(15, 0xF)
[10:56:33] LDO Bypass Successful
[10:56:33] [RadarAPI]: ar1.LPModConfig_mult(15, 0,0)
[10:56:33] Low Power Mode Configuration Successful
[10:56:33] [RadarAPI]: ar1.SetMiscConfig_mult(15, 1, 0, 0, 0)
[10:56:33] Misc Control Configuration Successful
[10:56:33] [RadarAPI]: ar1.RfInitCalibConfig_mult(15, 1, 1, 1, 1, 1, 1, 1, 65537)
[10:56:33] RF Init Calibration Successful
[10:56:33] [RadarAPI]: ar1.RfInit_mult(15)
[10:56:33] [DeviceId-3] RF Init async event received!
[10:56:33] [DeviceId-0] RF Init async event received!
[10:56:34] [DeviceId-1] RF Init async event received!
[10:56:34] [DeviceId-2] RF Init async event received!
[10:56:34] [RadarAPI]: Time stamp, Temperture: 6046,31; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 1, 1; RxIQMM Status, Update: 1, 1;
[10:56:34] [RadarAPI]: Status: Passed
[10:56:34] RF Init Successful
[10:56:34] [RadarAPI]: ar1.DataPathConfig_mult(15, 0, 1, 0)
[10:56:34] Data Path Configuration Successful
[10:56:34] [RadarAPI]: ar1.LvdsClkConfig_mult(15, 1,1)
[10:56:34] Clock Configuration Successful
[10:56:34] [RadarAPI]: ar1.CSI2LaneConfig_mult(15, 1, 0, 2, 0, 4, 0, 5,0,3,0, 0)
[10:56:34] CSI2 Configuration Successful
[10:56:34] [RadarAPI]: ar1.SetTestSource_mult(1, 4, 3, 0, 0, 0, 0, -327, 0, -327, 327, 327, 327, -2.5, 327, 327, 0, 0, 0, 0, -327, 0, -327, 327, 327, 327, -95, 0, 0, 0.5, 0, 1, 0, 1.5, 0, 0, 0, 0, 0, 0, 0, 0)
[10:56:35] Device 1 : Test Source Configuration Successful
[10:56:35] [RadarAPI]: ar1.SetTestSource_mult(2, 3, 4, 0, 0, 0, 0, -327, 0, -327, 327, 327, 327, -2.5, 327, 327, 0, 0, 0, 0, -327, 0, -327, 327, 327, 327, -95, 0, 0, 0.5, 0, 1, 0, 1.5, 0, 0, 0, 0, 0, 0, 0, 0)
[10:56:35] [RadarAPI]: Status: Passed
[10:56:35] Device 2 : Test Source Configuration Successful
[10:56:35] [RadarAPI]: ar1.SetTestSource_mult(4, 12, 5, 0, 0, 0, 0, -327, 0, -327, 327, 327, 327, -2.5, 327, 327, 0, 0, 0, 0, -327, 0, -327, 327, 327, 327, -95, 0, 0, 0.5, 0, 1, 0, 1.5, 0, 0, 0, 0, 0, 0, 0, 0)
[10:56:35] Device 3 : Test Source Configuration Successful
[10:56:35] [RadarAPI]: ar1.SetTestSource_mult(8, 5, 12, 0, 0, 0, 0, -327, 0, -327, 327, 327, 327, -2.5, 327, 327, 0, 0, 0, 0, -327, 0, -327, 327, 327, 327, -95, 0, 0, 0.5, 0, 1, 0, 1.5, 0, 0, 0, 0, 0, 0, 0, 0)
[10:56:35] Device 4 : Test Source Configuration Successful
[10:56:35] [RadarAPI]: ar1.ProfileConfig_mult(15, 0, 77, 5, 6, 40, 0, 0, 0, 0, 0, 0, 78.986, 0, 256, 8000, 0, 0, 48)
[10:56:35] Profile Configuration successful
[10:56:35] [RadarAPI]: ar1.ChirpConfig_mult(15, 0, 11, 0, 0, 0, 0, 0, 1, 1,0)
[10:56:35] Chirp 0 Configuration successful
[10:56:35] [RadarAPI]: ar1.EnableTestSource_mult(15,1)
[10:56:36] [RadarAPI]: Status: Passed
[10:56:36] Enabling Test Source Configuration successful
[10:56:36] Test Source Already Enabled...!!!
[10:56:36] [RadarAPI]: ar1.EnableTestSource_mult(1,1)
[10:56:36] [RadarAPI]: ar1.FrameConfig_mult(1, 0, 11, 10, 64, 100, 0, 1)
[10:56:37] Master : Frame Configuration successful
[10:56:37] Test Source Already Enabled...!!!
[10:56:37] [RadarAPI]: ar1.EnableTestSource_mult(14,1)
[10:56:37] [RadarAPI]: Status: Passed
[10:56:37] [RadarAPI]: ar1.FrameConfig_mult(14, 0, 11, 10, 64, 100, 0, 2)
[10:56:37] Slaves : Frame Configuration successful
[10:56:37]
[10:56:37] ***Script completed successfully.***
[10:56:41] LuaLoad("C:/ti/mmwave_studio_03_00_00_14/mmWaveStudio/Scripts/Cascade/Cascade_Capture.lua")
[10:56:44] Loops Remaining : 1
[10:56:44] Starting TDA ARM...
[10:56:44] [RadarAPI]: ar1.TDACaptureCard_StartRecord_mult(1, 0, 0, Cascade_Capture_22xx, 0)
[10:56:44] Device 0 - Configuring TDA with Width : 2048 and Height : 768
[10:56:44] [RadarAPI]: Device 0 - setWidthAndHeight Status: Passed
[10:56:44] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:56:44] Device 1 - Configuring TDA with Width : 2048 and Height : 768
[10:56:44] [RadarAPI]: Device 1 - setWidthAndHeight Status: Passed
[10:56:44] [RadarAPI]: Device 2 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:56:44] Device 2 - Configuring TDA with Width : 2048 and Height : 768
[10:56:44] [RadarAPI]: Device 2 - setWidthAndHeight Status: Passed
[10:56:44] [RadarAPI]: Device 4 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:56:44] Device 3 - Configuring TDA with Width : 2048 and Height : 768
[10:56:44] [RadarAPI]: Device 3 - setWidthAndHeight Status: Passed
[10:56:44] [RadarAPI]: Device 8 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:56:44] Sending Frame Periodicity of 100 to TDA..
[10:56:44] [RadarAPI]: Status: Passed. Frame Periodicity sent to TDA
[10:56:44] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:56:44] Sending Capture Directory with name /mnt/ssd/Cascade_Capture_22xx to TDA..
[10:56:44] [RadarAPI]: Status: Passed. Capture Directory sent to TDA
[10:56:44] Sending File Allocation of 0 files to TDA..
[10:56:44] [RadarAPI]: Status: Passed. File Allocation sent to TDA
[10:56:44] Sending Enable Data Packaging (0 - 16-bit; 1 - 12-bit) with value of 0 to TDA..
[10:56:44] [RadarAPI]: Status: Passed. Enable Data Packaging sent to TDA
[10:56:44] Sending Number of frames to capture with value of 0 to TDA..
[10:56:44] [RadarAPI]: Status: Passed. Number of frames to capture sent to TDA
[10:56:45] [RadarAPI]: Status: Passed for notifying TDA about Creating Application
[10:56:45] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:56:45] [RadarAPI]: Status: Passed for notifying TDA about Start Frame
[10:56:45] TDA ARM Successful
[10:56:46] Starting Frame Trigger sequence...
[10:56:46] [RadarAPI]: ar1.StartFrame_mult(8)
[10:56:46] [RadarAPI]: Status: Passed
[10:56:46] Device 4 : Start Frame Successful
[10:56:46] [RadarAPI]: ar1.StartFrame_mult(4)
[10:56:46] [DeviceId-3] Frame start async event received!
[10:56:47] [RadarAPI]: Status: Passed
[10:56:47] Device 3 : Start Frame Successful
[10:56:47] [RadarAPI]: ar1.StartFrame_mult(2)
[10:56:47] [DeviceId-2] Frame start async event received!
[10:56:47] Device 2 : Start Frame Successful
[10:56:47] [RadarAPI]: ar1.StartFrame_mult(1)
[10:56:47] [DeviceId-1] Frame start async event received!
[10:56:47] Device 1 : Start Frame Successful
[10:56:47] Capturing AWR device data to the TDA SSD...
[10:56:48] [RadarAPI]: Frame Ended
[10:56:48] CAPTURE_RESPONSE_NETWORK_ERROR Async event recieved! Connection error! Please reboot the TDA board
[10:56:48] [RadarAPI]: ar1.RemoveDevice(8)
[10:56:48] [RadarAPI]: Status: Passed
[10:56:48] [RadarAPI]: ar1.RemoveDevice(4)
[10:56:48] [RadarAPI]: ar1.RemoveDevice(2)
[10:56:49] Capture sequence completed...
[10:56:51] Starting Transfer files using WinSCP..
[10:57:13] [RadarAPI]: Error: Network error: Connection to "192.168.33.180" timed out.
[10:57:13] Transferring files FAILED!
[10:57:13]
[10:57:13] ***Script completed successfully.***
Use case-2
GM: Constructor
GM: Mon Feb 24 10:42:39 2025
[10:42:40]
[10:42:40] ### Running Startup script: "C:\ti\mmwave_studio_03_00_00_14\mmWaveStudio\Scripts\Startup.lua" ###
[10:42:40] RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
[10:42:40] RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
[10:42:40] Scripter ignored: Attempt to UnBuild() again or before Build.
[10:42:40] RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "C:\\ti\\mmwave_studio_03_00_00_14\\mmWaveStudio\\Clients\\\\LabClient.dll")
[10:42:40] RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
[10:42:40] RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
[10:42:40] RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
[10:42:40] RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
[10:42:40] RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
[10:42:40] RSTD.SetVar ("/Settings/AL Client/AL Dll" , "C:\\ti\\mmwave_studio_03_00_00_14\\mmWaveStudio\\RunTime\\SAL.dll")
[10:42:40] RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
[10:42:40] RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
[10:42:40] RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
[10:42:40] RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
[10:42:40] RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
[10:42:40] RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
[10:42:40] RSTD.Transmit("/")
[10:42:40] RSTD.SaveSettings(): Settings saved to "C:\Users\Admin\AppData\Roaming\RSTD\config.xml"
[10:42:40] RSTD.Build()
[10:42:40] RSTD.AL_Build()
[10:42:40] RSTD.AL_LoadXml()
[10:42:40] RSTD.AL_Init()
[10:42:40] RSTD.Clients_Build()
[10:42:40] GM: Init
[10:42:40] GM: Loaded 'C:\ti\mmwave_studio_03_00_00_14\mmWaveStudio\Clients\\LabClient.dll'
[10:42:40] GM: 1 Guest (s) init
[10:42:40] GM: 1 Module(s) init
[10:42:40] GM: 2 Tab (s) init
[10:42:40] RSTD.Client_LoadXml()
[10:42:41] [RadarAPI]: ar1.selectRadarMode(0)
[10:42:41] [RadarAPI]: Status: Passed
[10:42:41] Matlab Runtime Engine is installed
[10:42:41] [RadarAPI]: Starting Matlab Engine..
[10:42:49] [RadarAPI]: Matlab Engine Started!
[10:42:52] [RadarAPI]: ar1.selectCascadeMode(0)
[10:42:52] [RadarAPI]: Status: Passed
[10:42:52] [RadarAPI]: ar1.LoadSettings('C:\Users\Admin\AppData\Roaming\RSTD\ar1gui.ini')
[10:42:53] TESTING = false
[10:42:53] RstdNet: Port 2777: Listening..
[10:42:53]
[10:42:53] ***Script completed successfully.***
[10:43:02] [RadarAPI]: ar1.selectRadarMode(1)
[10:43:02] [RadarAPI]: ar1.selectCascadeMode(1)
[10:43:02] [RadarAPI]: Status: Passed
[10:43:04] [RadarAPI]: ar1.SelectCaptureDevice("TDA2XX")
[10:43:04] [RadarAPI]: Status: Passed
[10:43:18] [RadarAPI]: TDAStatusCallback Event Registered
[10:43:18] [RadarAPI]: registerTDAStatusCallback Status: Passed
[10:43:18] [RadarAPI]: ar1.ConnectTDA("192.168.33.180", 5001, 15)
[10:43:18] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:43:18] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_VERSION_INFO Async event recieved() with status 0. TDA Version : REL_VISION_SDK_03_07_01_00 Aug 5 2019 15:04:45[10:43:18] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:43:19] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:43:19] [RadarAPI]: ConnectTDACaptureCard Status: Passed
[10:43:19] TDA Capture Card Status : CONNECTED!
[10:43:37] LuaLoad("C:/ti/mmwave_studio_03_00_00_14/mmWaveStudio/Scripts/Cascade/Cascade_Configuration_MIMO.lua")
[10:43:48] Setting up Studio for Cascade started..
[10:43:48] [RadarAPI]: Connection to the TDA is already established!
[10:43:48] ConnectTDA Successful
[10:43:48] selectCascadeMode Successful
[10:43:48] Setting up Studio for Cascade ended..
[10:43:48] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:43:49] [RadarAPI]: ar1.FullReset(1)
[10:43:49] [RadarAPI]: Status: Passed
[10:43:49] [RadarAPI]: ar1.SOPControl_mult(1,4)
[10:43:49] Master : SOP Reset Successful
[10:43:49] [RadarAPI]: ar1.PowerOn_mult(1, 0, 1000, 0,0)
[10:43:49] [DeviceId-0] MSS power up done async event received!
[10:43:49] Master : SPI Connection Successful
[10:43:49] [RadarAPI]: ar1.DownloadBssFwOvSPI_mult(1, C:\\ti\\mmwave_dfp_02_02_02_01\\firmware\\xwr22xx_metaImage.bin)
[10:43:52] Master : FW Download Successful
[10:43:53] [RadarAPI]: ar1.SelectChipVersion("AR1243")
[10:43:53] [RadarAPI]: Status: Passed
[10:43:53] [RadarAPI]: ar1.deviceVariantSelection("XWR2243")
[10:43:53] [RadarAPI]: ar1.frequencyBandSelection("77G")
[10:43:53] [RadarAPI]: ar1.SelectChipVersion("XWR2243")
[10:43:53] Device Status : XWR2243/ASIL-B/SOP:4/ES:1.1
[10:43:54] [RadarAPI]: ar1.RfEnable_mult(1)
[10:43:54] [DeviceId-0] BSS power up done async event received!
[10:43:54] [RadarAPI]: Status: Passed
[10:43:55] Master : RF Power Up Successful
[10:43:55] [RadarAPI]: ar1.ChanNAdcConfig_mult(1, 1, 1, 1, 1, 1, 1, 1, 2, 1, 0, 1)
[10:43:56] [RadarAPI]: Status: Passed
[10:43:56] Master : Channel & ADC Configuration Successful
[10:43:56] [RadarAPI]: Device 2 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:43:57] [RadarAPI]: ar1.FullReset(2)
[10:43:57] [RadarAPI]: Status: Passed
[10:43:57] [RadarAPI]: ar1.SOPControl_mult(2,4)
[10:43:57] Device 2 : SOP Reset Successful
[10:43:57] [DeviceId-1] MSS power up done async event received!
[10:43:57] [RadarAPI]: ar1.AddDevice(2)
[10:43:57] Device 2 : SPI Connection Successful
[10:43:57] [RadarAPI]: Device 4 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:43:58] [RadarAPI]: ar1.FullReset(4)
[10:43:58] [RadarAPI]: Status: Passed
[10:43:58] [RadarAPI]: ar1.SOPControl_mult(4,4)
[10:43:58] Device 3 : SOP Reset Successful
[10:43:58] [DeviceId-2] MSS power up done async event received!
[10:43:58] [RadarAPI]: ar1.AddDevice(4)
[10:43:58] Device 3 : SPI Connection Successful
[10:43:58] [RadarAPI]: Device 8 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:43:59] [RadarAPI]: ar1.FullReset(8)
[10:43:59] [RadarAPI]: Status: Passed
[10:43:59] [RadarAPI]: ar1.SOPControl_mult(8,4)
[10:43:59] Device 4 : SOP Reset Successful
[10:43:59] [DeviceId-3] MSS power up done async event received!
[10:43:59] [RadarAPI]: ar1.AddDevice(8)
[10:43:59] Device 4 : SPI Connection Successful
[10:43:59] [RadarAPI]: ar1.DownloadBssFwOvSPI_mult(14, C:\\ti\\mmwave_dfp_02_02_02_01\\firmware\\xwr22xx_metaImage.bin)
[10:44:03] Slaves : FW Download Successful
[10:44:04] [RadarAPI]: ar1.SelectChipVersion("AR1243")
[10:44:04] [RadarAPI]: Status: Passed
[10:44:04] [RadarAPI]: ar1.SelectChipVersion("XWR2243")
[10:44:04] Slave1 Device Status : XWR2243/ASIL-B/SOP:4/ES:1.1
[10:44:05] [RadarAPI]: ar1.SelectChipVersion("AR1243")
[10:44:05] [RadarAPI]: Status: Passed
[10:44:05] [RadarAPI]: ar1.SelectChipVersion("XWR2243")
[10:44:05] Slave2 Device Status : XWR2243/ASIL-B/SOP:4/ES:1.1
[10:44:06] [RadarAPI]: ar1.SelectChipVersion("AR1243")
[10:44:06] [RadarAPI]: Status: Passed
[10:44:06] [RadarAPI]: ar1.SelectChipVersion("XWR2243")
[10:44:06] Slave3 Device Status : XWR2243/ASIL-B/SOP:4/ES:1.1
[10:44:06] [RadarAPI]: ar1.RfEnable_mult(14)
[10:44:06] [DeviceId-2] BSS power up done async event received!
[10:44:07] [DeviceId-1] BSS power up done async event received!
[10:44:07] [DeviceId-3] BSS power up done async event received!
[10:44:07] [RadarAPI]: Status: Passed
[10:44:11] Slaves : RF Power Up Successful
[10:44:11] [RadarAPI]: ar1.ChanNAdcConfig_mult(14, 1, 1, 1, 1, 1, 1, 1, 2, 1, 0, 2)
[10:44:12] [RadarAPI]: Status: Passed
[10:44:12] Slaves : Channel & ADC Configuration Successful
[10:44:12] [RadarAPI]: ar1.RfLdoBypassConfig_mult(15, 0xF)
[10:44:12] LDO Bypass Successful
[10:44:12] [RadarAPI]: ar1.LPModConfig_mult(15, 0,0)
[10:44:12] Low Power Mode Configuration Successful
[10:44:12] [RadarAPI]: ar1.SetMiscConfig_mult(15, 1, 0, 0, 0)
[10:44:12] Misc Control Configuration Successful
[10:44:12] [RadarAPI]: ar1.RfInitCalibConfig_mult(15, 1, 1, 1, 1, 1, 1, 1, 65537)
[10:44:12] RF Init Calibration Successful
[10:44:12] [RadarAPI]: ar1.RfInit_mult(15)
[10:44:12] [DeviceId-0] RF Init async event received!
[10:44:12] [DeviceId-1] RF Init async event received!
[10:44:12] [DeviceId-3] RF Init async event received!
[10:44:12] [DeviceId-2] RF Init async event received!
[10:44:13] [RadarAPI]: Time stamp, Temperture: 18721,34; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 1, 1; RxIQMM Status, Update: 1, 1;
[10:44:13] [RadarAPI]: Time stamp, Temperture: 5925,32; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 1, 1; RxIQMM Status, Update: 1, 1;
[10:44:13] [RadarAPI]: Time stamp, Temperture: 5925,34; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 1, 1; RxIQMM Status, Update: 1, 1;
[10:44:13] [RadarAPI]: Status: Passed
[10:44:13] RF Init Successful
[10:44:13] [RadarAPI]: ar1.DataPathConfig_mult(15, 0, 1, 0)
[10:44:13] Data Path Configuration Successful
[10:44:13] [RadarAPI]: ar1.LvdsClkConfig_mult(15, 1,1)
[10:44:13] Clock Configuration Successful
[10:44:13] [RadarAPI]: ar1.CSI2LaneConfig_mult(15, 1, 0, 2, 0, 4, 0, 5,0,3,0, 0)
[10:44:13] CSI2 Configuration Successful
[10:44:13] [RadarAPI]: ar1.ProfileConfig_mult(15, 0, 77, 5, 6, 40, 0, 0, 0, 0, 0, 0, 78.986, 0, 256, 8000, 0, 0, 48)
[10:44:14] [RadarAPI]: Status: Passed
[10:44:14] Profile Configuration successful
[10:44:14] [RadarAPI]: ar1.ChirpConfig_mult(1, 0, 0, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:14] Device 1 : Chirp 0 Configuration successful
[10:44:14] [RadarAPI]: ar1.ChirpConfig_mult(1, 1, 1, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:14] Device 1 : Chirp 1 Configuration successful
[10:44:14] [RadarAPI]: ar1.ChirpConfig_mult(1, 2, 2, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:14] Device 1 : Chirp 2 Configuration successful
[10:44:14] [RadarAPI]: ar1.ChirpConfig_mult(1, 3, 3, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:14] Device 1 : Chirp 3 Configuration successful
[10:44:14] [RadarAPI]: ar1.ChirpConfig_mult(1, 4, 4, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:14] Device 1 : Chirp 4 Configuration successful
[10:44:14] [RadarAPI]: ar1.ChirpConfig_mult(1, 5, 5, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:14] Device 1 : Chirp 5 Configuration successful
[10:44:14] [RadarAPI]: ar1.ChirpConfig_mult(1, 6, 6, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:15] Device 1 : Chirp 6 Configuration successful
[10:44:15] [RadarAPI]: ar1.ChirpConfig_mult(1, 7, 7, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:15] [RadarAPI]: Status: Passed
[10:44:15] Device 1 : Chirp 7 Configuration successful
[10:44:15] [RadarAPI]: ar1.ChirpConfig_mult(1, 8, 8, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:15] Device 1 : Chirp 8 Configuration successful
[10:44:15] [RadarAPI]: ar1.ChirpConfig_mult(1, 9, 9, 0, 0, 0, 0, 0, 0, 0,1)
[10:44:15] Device 1 : Chirp 9 Configuration successful
[10:44:15] [RadarAPI]: ar1.ChirpConfig_mult(1, 10, 10, 0, 0, 0, 0, 0, 0, 1,0)
[10:44:15] Device 1 : Chirp 10 Configuration successful
[10:44:15] [RadarAPI]: ar1.ChirpConfig_mult(1, 11, 11, 0, 0, 0, 0, 0, 1, 0,0)
[10:44:15] Device 1 : Chirp 11 Configuration successful
[10:44:15] [RadarAPI]: ar1.ChirpConfig_mult(2, 0, 0, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:16] [RadarAPI]: Status: Passed
[10:44:16] Device 2 : Chirp 0 Configuration successful
[10:44:16] [RadarAPI]: ar1.ChirpConfig_mult(2, 1, 1, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:16] Device 2 : Chirp 1 Configuration successful
[10:44:16] [RadarAPI]: ar1.ChirpConfig_mult(2, 2, 2, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:16] Device 2 : Chirp 2 Configuration successful
[10:44:16] [RadarAPI]: ar1.ChirpConfig_mult(2, 3, 3, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:16] Device 2 : Chirp 3 Configuration successful
[10:44:16] [RadarAPI]: ar1.ChirpConfig_mult(2, 4, 4, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:16] Device 2 : Chirp 4 Configuration successful
[10:44:16] [RadarAPI]: ar1.ChirpConfig_mult(2, 5, 5, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:16] Device 2 : Chirp 5 Configuration successful
[10:44:16] [RadarAPI]: ar1.ChirpConfig_mult(2, 6, 6, 0, 0, 0, 0, 0, 0, 0,1)
[10:44:16] Device 2 : Chirp 6 Configuration successful
[10:44:16] [RadarAPI]: ar1.ChirpConfig_mult(2, 7, 7, 0, 0, 0, 0, 0, 0, 1,0)
[10:44:17] [RadarAPI]: Status: Passed
[10:44:17] Device 2 : Chirp 7 Configuration successful
[10:44:17] [RadarAPI]: ar1.ChirpConfig_mult(2, 8, 8, 0, 0, 0, 0, 0, 1, 0,0)
[10:44:17] Device 2 : Chirp 8 Configuration successful
[10:44:17] [RadarAPI]: ar1.ChirpConfig_mult(2, 9, 9, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:17] Device 2 : Chirp 9 Configuration successful
[10:44:17] [RadarAPI]: ar1.ChirpConfig_mult(2, 10, 10, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:17] Device 2 : Chirp 10 Configuration successful
[10:44:17] [RadarAPI]: ar1.ChirpConfig_mult(2, 11, 11, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:17] Device 2 : Chirp 11 Configuration successful
[10:44:17] [RadarAPI]: ar1.ChirpConfig_mult(4, 0, 0, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:17] Device 3 : Chirp 0 Configuration successful
[10:44:17] [RadarAPI]: ar1.ChirpConfig_mult(4, 1, 1, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:17] Device 3 : Chirp 1 Configuration successful
[10:44:17] [RadarAPI]: ar1.ChirpConfig_mult(4, 2, 2, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:17] Device 3 : Chirp 2 Configuration successful
[10:44:17] [RadarAPI]: ar1.ChirpConfig_mult(4, 3, 3, 0, 0, 0, 0, 0, 0, 0,1)
[10:44:18] [RadarAPI]: Status: Passed
[10:44:18] Device 3 : Chirp 3 Configuration successful
[10:44:18] [RadarAPI]: ar1.ChirpConfig_mult(4, 4, 4, 0, 0, 0, 0, 0, 0, 1,0)
[10:44:18] Device 3 : Chirp 4 Configuration successful
[10:44:18] [RadarAPI]: ar1.ChirpConfig_mult(4, 5, 5, 0, 0, 0, 0, 0, 1, 0,0)
[10:44:18] Device 3 : Chirp 5 Configuration successful
[10:44:18] [RadarAPI]: ar1.ChirpConfig_mult(4, 6, 6, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:18] Device 3 : Chirp 6 Configuration successful
[10:44:18] [RadarAPI]: ar1.ChirpConfig_mult(4, 7, 7, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:18] Device 3 : Chirp 7 Configuration successful
[10:44:18] [RadarAPI]: ar1.ChirpConfig_mult(4, 8, 8, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:18] Device 3 : Chirp 8 Configuration successful
[10:44:18] [RadarAPI]: ar1.ChirpConfig_mult(4, 9, 9, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:18] Device 3 : Chirp 9 Configuration successful
[10:44:18] [RadarAPI]: ar1.ChirpConfig_mult(4, 10, 10, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:19] [RadarAPI]: Status: Passed
[10:44:19] Device 3 : Chirp 10 Configuration successful
[10:44:19] [RadarAPI]: ar1.ChirpConfig_mult(4, 11, 11, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:19] Device 3 : Chirp 11 Configuration successful
[10:44:19] [RadarAPI]: ar1.ChirpConfig_mult(8, 0, 0, 0, 0, 0, 0, 0, 0, 0,1)
[10:44:19] Device 4 : Chirp 0 Configuration successful
[10:44:19] [RadarAPI]: ar1.ChirpConfig_mult(8, 1, 1, 0, 0, 0, 0, 0, 0, 1,0)
[10:44:19] Device 4 : Chirp 1 Configuration successful
[10:44:19] [RadarAPI]: ar1.ChirpConfig_mult(8, 2, 2, 0, 0, 0, 0, 0, 1, 0,0)
[10:44:19] Device 4 : Chirp 2 Configuration successful
[10:44:19] [RadarAPI]: ar1.ChirpConfig_mult(8, 3, 3, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:19] Device 4 : Chirp 3 Configuration successful
[10:44:19] [RadarAPI]: ar1.ChirpConfig_mult(8, 4, 4, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:19] Device 4 : Chirp 4 Configuration successful
[10:44:19] [RadarAPI]: ar1.ChirpConfig_mult(8, 5, 5, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:20] [RadarAPI]: Status: Passed
[10:44:20] Device 4 : Chirp 5 Configuration successful
[10:44:20] [RadarAPI]: ar1.ChirpConfig_mult(8, 6, 6, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:20] Device 4 : Chirp 6 Configuration successful
[10:44:20] [RadarAPI]: ar1.ChirpConfig_mult(8, 7, 7, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:20] Device 4 : Chirp 7 Configuration successful
[10:44:20] [RadarAPI]: ar1.ChirpConfig_mult(8, 8, 8, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:20] Device 4 : Chirp 8 Configuration successful
[10:44:20] [RadarAPI]: ar1.ChirpConfig_mult(8, 9, 9, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:20] Device 4 : Chirp 9 Configuration successful
[10:44:20] [RadarAPI]: ar1.ChirpConfig_mult(8, 10, 10, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:20] Device 4 : Chirp 10 Configuration successful
[10:44:20] [RadarAPI]: ar1.ChirpConfig_mult(8, 11, 11, 0, 0, 0, 0, 0, 0, 0,0)
[10:44:20] Device 4 : Chirp 11 Configuration successful
[10:44:21] Test Source Already Disabled...!!!
[10:44:21] [RadarAPI]: ar1.DisableTestSource_mult(1,0)
[10:44:21] [RadarAPI]: Status: Passed
[10:44:21] [RadarAPI]: ar1.FrameConfig_mult(1, 0, 11, 10, 64, 100, 0, 1)
[10:44:21] Master : Frame Configuration successful
[10:44:21] [RadarAPI]: ar1.DisableTestSource_mult(14,0)
[10:44:21] [RadarAPI]: ar1.FrameConfig_mult(14, 0, 11, 10, 64, 100, 0, 2)
[10:44:21] Slaves : Frame Configuration successful
[10:44:21]
[10:44:21] ***Script completed successfully.***
[10:44:32] LuaLoad("C:/ti/mmwave_studio_03_00_00_14/mmWaveStudio/Scripts/Cascade/Cascade_Capture.lua")
[10:44:34] Loops Remaining : 1
[10:44:34] Starting TDA ARM...
[10:44:34] [RadarAPI]: ar1.TDACaptureCard_StartRecord_mult(1, 0, 0, Cascade_Capture_22xx, 0)
[10:44:34] Device 0 - Configuring TDA with Width : 2048 and Height : 768
[10:44:34] [RadarAPI]: Device 0 - setWidthAndHeight Status: Passed
[10:44:34] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:44:34] Device 1 - Configuring TDA with Width : 2048 and Height : 768
[10:44:34] [RadarAPI]: Device 1 - setWidthAndHeight Status: Passed
[10:44:34] [RadarAPI]: Device 2 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:44:34] Device 2 - Configuring TDA with Width : 2048 and Height : 768
[10:44:34] [RadarAPI]: Device 2 - setWidthAndHeight Status: Passed
[10:44:34] [RadarAPI]: Device 4 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:44:34] Device 3 - Configuring TDA with Width : 2048 and Height : 768
[10:44:34] [RadarAPI]: Device 3 - setWidthAndHeight Status: Passed
[10:44:34] [RadarAPI]: Device 8 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:44:34] Sending Frame Periodicity of 100 to TDA..
[10:44:34] [RadarAPI]: Status: Passed. Frame Periodicity sent to TDA
[10:44:34] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:44:35] Sending Capture Directory with name /mnt/ssd/Cascade_Capture_22xx to TDA..
[10:44:35] [RadarAPI]: Status: Passed. Capture Directory sent to TDA
[10:44:35] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:44:35] Sending File Allocation of 0 files to TDA..
[10:44:35] [RadarAPI]: Status: Passed. File Allocation sent to TDA
[10:44:35] Sending Enable Data Packaging (0 - 16-bit; 1 - 12-bit) with value of 0 to TDA..
[10:44:35] [RadarAPI]: Status: Passed. Enable Data Packaging sent to TDA
[10:44:35] Sending Number of frames to capture with value of 0 to TDA..
[10:44:35] [RadarAPI]: Status: Passed. Number of frames to capture sent to TDA
[10:44:35] [RadarAPI]: Status: Passed for notifying TDA about Creating Application
[10:44:35] [RadarAPI]: Status: Passed for notifying TDA about Start Frame
[10:44:35] TDA ARM Successful
[10:44:36] Starting Frame Trigger sequence...
[10:44:36] [RadarAPI]: ar1.StartFrame_mult(8)
[10:44:36] [RadarAPI]: Status: Passed
[10:44:36] Device 4 : Start Frame Successful
[10:44:36] [RadarAPI]: ar1.StartFrame_mult(4)
[10:44:37] [DeviceId-3] Frame start async event received!
[10:44:37] [RadarAPI]: Status: Passed
[10:44:37] Device 3 : Start Frame Successful
[10:44:37] [RadarAPI]: ar1.StartFrame_mult(2)
[10:44:37] [DeviceId-2] Frame start async event received!
[10:44:37] Device 2 : Start Frame Successful
[10:44:37] [RadarAPI]: ar1.StartFrame_mult(1)
[10:44:37] [DeviceId-1] Frame start async event received!
[10:44:37] Device 1 : Start Frame Successful
[10:44:37] Capturing AWR device data to the TDA SSD...
[10:44:37] [DeviceId-0] Frame start async event received!
[10:44:38] [RadarAPI]: Frame Ended
[10:44:38] [DeviceId-0] Frame End async event received!
[10:44:38] [DeviceId-1] Frame End async event received!
[10:44:38] [DeviceId-2] Frame End async event received!
[10:44:38] [DeviceId-3] Frame End async event received!
[10:44:38] Status: Passed for notifying TDA about Stop Frame
[10:44:38] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:44:39] Capture sequence completed...
[10:44:41] Starting Transfer files using WinSCP..
[10:44:44] Downloading file /mnt/ssd/Cascade_Capture_22xx/master_0000_data.bin...
[10:44:50] Downloaded file /mnt/ssd/Cascade_Capture_22xx/master_0000_data.bin from SSD!
[10:44:50] Downloading file /mnt/ssd/Cascade_Capture_22xx/master_0000_idx.bin...
[10:44:50] Downloaded file /mnt/ssd/Cascade_Capture_22xx/master_0000_idx.bin from SSD!
[10:44:50] Downloading file /mnt/ssd/Cascade_Capture_22xx/master_0001_data.bin...
[10:44:56] Downloaded file /mnt/ssd/Cascade_Capture_22xx/master_0001_data.bin from SSD!
[10:44:56] Downloading file /mnt/ssd/Cascade_Capture_22xx/master_0001_idx.bin...
[10:44:56] Downloaded file /mnt/ssd/Cascade_Capture_22xx/master_0001_idx.bin from SSD!
[10:44:56] Downloading file /mnt/ssd/Cascade_Capture_22xx/slave1_0000_data.bin...
[10:45:01] Downloaded file /mnt/ssd/Cascade_Capture_22xx/slave1_0000_data.bin from SSD!
[10:45:01] Downloading file /mnt/ssd/Cascade_Capture_22xx/slave1_0000_idx.bin...
[10:45:01] Downloaded file /mnt/ssd/Cascade_Capture_22xx/slave1_0000_idx.bin from SSD!
[10:45:01] Downloading file /mnt/ssd/Cascade_Capture_22xx/slave1_0001_data.bin...
[10:45:06] Downloaded file /mnt/ssd/Cascade_Capture_22xx/slave1_0001_data.bin from SSD!
[10:45:06] Downloading file /mnt/ssd/Cascade_Capture_22xx/slave1_0001_idx.bin...
[10:45:06] Downloaded file /mnt/ssd/Cascade_Capture_22xx/slave1_0001_idx.bin from SSD!
[10:45:06] Downloading file /mnt/ssd/Cascade_Capture_22xx/slave2_0000_data.bin...
[10:45:11] Downloaded file /mnt/ssd/Cascade_Capture_22xx/slave2_0000_data.bin from SSD!
[10:45:11] Downloading file /mnt/ssd/Cascade_Capture_22xx/slave2_0000_idx.bin...
[10:45:11] Downloaded file /mnt/ssd/Cascade_Capture_22xx/slave2_0000_idx.bin from SSD!
[10:45:11] Downloading file /mnt/ssd/Cascade_Capture_22xx/slave2_0001_data.bin...
[10:45:16] Downloaded file /mnt/ssd/Cascade_Capture_22xx/slave2_0001_data.bin from SSD!
[10:45:16] Downloading file /mnt/ssd/Cascade_Capture_22xx/slave2_0001_idx.bin...
[10:45:16] Downloaded file /mnt/ssd/Cascade_Capture_22xx/slave2_0001_idx.bin from SSD!
[10:45:16] Downloading file /mnt/ssd/Cascade_Capture_22xx/slave3_0000_data.bin...
[10:45:21] Downloaded file /mnt/ssd/Cascade_Capture_22xx/slave3_0000_data.bin from SSD!
[10:45:21] Downloading file /mnt/ssd/Cascade_Capture_22xx/slave3_0000_idx.bin...
[10:45:21] Downloaded file /mnt/ssd/Cascade_Capture_22xx/slave3_0000_idx.bin from SSD!
[10:45:21] Downloading file /mnt/ssd/Cascade_Capture_22xx/slave3_0001_data.bin...
[10:45:26] Downloaded file /mnt/ssd/Cascade_Capture_22xx/slave3_0001_data.bin from SSD!
[10:45:26] Downloading file /mnt/ssd/Cascade_Capture_22xx/slave3_0001_idx.bin...
[10:45:27] Downloaded file /mnt/ssd/Cascade_Capture_22xx/slave3_0001_idx.bin from SSD!
[10:45:29] Export Operation was successful!
[10:45:29] [RadarAPI]: Transfer of the Captured files COMPLETE!
[10:45:29] Transferred files! COMPLETE!
[10:45:29]
[10:45:29] ***Script completed successfully.***
kindly resolve this issue. thanks in advance.
