I checked the SDK user guide, but can't find param to disable FFT. Would you pls kindly advise if mmw demo support ADC output from ethernet by AWR2544?
Chris
Chris
Hello Chris,
Out of box we do not support this mainly as 1 Gbps is to sufficient to send out a lot of the complex chirps which customers send out.
If the data generated by customer in ADC is lesser than the 1 Gbps throughput, they can manually omit out the code for the 1D FFT and transfer over the ethernet.
We dont support it by default, but its upto customer.
But 1 Gbps is definitely not sufficient for streaming out data at such fast rate, the reason we use the 1-D FFT compressed data.
Saswat Kumar
