TMP175-Q1: TMP175 set to 12bits temp resolution cannot set successfully
Part Number: TMP175-Q1
Hello Application teams:
   we try to set TMP175-Q1 expect the  resolution of data0 temperature should be changed to "12 bits" after issued 0x72 to configuration register 0x01 . See below register setting .
But the query result remains in 8bits. you can refer the 0x0 pointer = 0x37 , could you please help give us comments what's our some missing setting ?   thank you
  • Hello Roy,
    To change the resolution of the device, you will need to change bit D5 and D6 with the Configuration Register. R1 and R0 should be changed to a 1. Can you provide a communication log of how you are writing to TMP175-Q1? This will help me further debug your issue.
    Meredith McKean
