Other Parts Discussed in Thread: UNIFLASH,
Dear Texas Instruments Support Team,
Hello, I have developed a custom board based on the IWRL1432BOOST reference design.
The TM4C1294NCPDTT3 (used as the XDS110 debugger) has been successfully programmed with the appropriate bootloader and firmware files.
I am now attempting to upload firmware to the IWRL1432 IC using UniFlash via the UART interface.
However, the COM port connection fails, and no communication is established.
I suspect the issue is due to the IWRL1432 being in its factory-default state, meaning no firmware has been previously programmed into the device.
Could you please guide me on the proper procedure for uploading firmware to a factory-fresh IWRL1432 IC?
Additionally, should both SOP0 and SOP1 pins be set HIGH for this initial programming stage?
Your support would be greatly appreciated.
Jaehoon Kim
