Hi Team,
We have been using this sensor in large volumes for over six years, and it has consistently performed well without any failures. However, in our new design, we recently observed two instances where the sensor failed after testing. In both cases, the sensor output was 0V, whereas it should have been approximately 0.9V under normal operation.
It's important to note that during start of test, both the supply voltage and output voltage were found to be within the specified limits. Also we have crosschecked by replacing sensor with healthy one on same ECU and checked faulty sensor on healthy ECU. This sensor is powered by 5V LDO.
In light of this, we request your support in identifying the possible root causes of failure in this new design and guidance on how to systematically verify what might have gone wrong.
