1)Can we use 90 to 100% duty cycle with AWR1843Boost with 3Tx ,4Rx configuration? Datasheet mentioned 50% max we can used.
2)What could be power dissipation for respective duty cycle used how we can calculate please explore how to calculate.
3)What can be configuration values for maximum duty cycle with respect to chirp frame ADC sampling time?
4) Are there any Memory limitations for using higher duty cycle configuration?
5)Heatsink required for higher duty cycle used?
6)We have to perform thermal modeling for our custom AWR1843 board can we get thermal modeling module based on varies duty cycles.
7)We are using approx. 4.5% duty cycle due to memory limitation as we are real taking data on CAN whenever required, suggest how we can increase duty cycle? Required which hardware changes?
