AWR1843BOOST: Debug break point problem.
Part Number: AWR1843BOOST
Hey, when I debugging my project, I met a problem that I cannot assert my break point. The break point shows like this, which indicate there is no symbol related with it. Can you help me solve this issue?
    The reason for this behavior is that code is optimized.
    One option is to open a disassembly window and set the breakpoint in the disassembly window.
    Another option is to reduce the Optimization Level of the code - this is a compiler option. However decreasing the Optimization Level may increase the memory size and the code may no longer fit in the available memory
    thank you
    Cesar
