Other Parts Discussed in Thread: DRV411
When I apply a large magnetic field the sensor saturated and voltage output is low. After removing the field and apply a field less than the maximum the sensor respons is normal again. However, when i apply the reversed field, with equal magnitude the sensor voltage output is high . After I remove the field the sensor stays high and it does not recover .
It only recovered when i turn of the power to the sensor or use a strong magnet close to the sensor in reverse direction .
I had an older same sensor , but although saturation amiccured it always recovered.
How can I prevent that the sensor stops measuring after a high magnetic field has been removed?
Thanks for answers.
