Hi Experter,
I am using FDC to detect the proximity. I met some issues. Can you help them?
My sensor is cylindrical copper foil. And it is connected to IN0A. The issues are describled as the lists
- When the FDC is powered on, FDC can measure a frequecy A. Normally, when a person is close to the sensor, the frequency should be decreased. But, sometimes, the measured frequency will be increased. And, I must power off the FDC in order that FDC work normally. Can you explain this?
- I followed John's suggestion to add a buffer circuit as the active shielding. However, when I connected the shielding, the measred value is disturbed so that I cannot get the normal value. Therefore, how to fix this?
- About the capacity sensor, is there any document to describle how to design. How to configure the circuir of FDC?
