TPS8802: How do I connect VBST and VLX pins when boost converter is not used
Part Number: TPS8802
Hello Everyone,
I was using TPS8802DCPR in one my designs. I was wondering how do I connect VBST and VLX pins if the boost converter is not used. In data sheet's pin description it says "Boost converter feedback and power input" about VBST pin. So if I don't have to use boost conversion, should I connect this pin to my supply??
Also is the boost conversion necessary if I am supplying 3.3V??
Link for datasheet: https://www.ti.com/lit/ds/symlink/tps8802.pdf?ts=1753250197657
If anyone has clarity about VBST and VLX pins. Please do share the information.
Thanks in advance..!!
