we tested the true ground speed demo with the IWR6843-ISK in a simulated test and are so far very statisfied with the results. However we encountered several problems along the way:
* The radar frequently crashes and no longer sends data. This only happens in confined areas (e.g. indoors). Do you know why this might happen? This is our main problem since we want to do a field test and cant restart the radar manually.
* How can we parse the speed data like in the demo without the visualizer? The demo says "The calculated velocity is streamed off the device as a TLV in real time via UART." but it does not say what TLV identifier is used.
* RANSAC (configRANSAC) is enabled by default in the demo. When turning it off or removing this line, the demo program no longer works. Why is that?
Your help would be greatly appreciated!
Noel
