LP-MSPM0G3519: Missing PWM Channel ID Defines in Pwm_Cfg.h
Part Number: LP-MSPM0G3519
Dear TI Support Team,
We have identified a potential issue in the following generated file:
mcal_config\plugins\MSPM0G351x\AUTOSAR_431\Pwm_TI_MSPM0G351x\generate\include\Pwm_Cfg.h
It appears that the symbolic names and defines for the PWM Channel IDs are missing. Specifically, the section that should define the symbolic names for each configured PWM channel is either not generated or omitted during code generation.
Expected section (example from template):
/** * \brief Channel ID * Symbolic Names Configured channel ID(s) */ [!LOOP "as:modconf('Pwm')[1]/PwmChannelConfigSet/PwmChannel/*"!] #define PwmConf_PwmChannel_[!"@name"!] ([!"PwmChannelId"!]U) /**< Channel identifiers */ [!ENDLOOP!]
However, this section does not appear to be present in the generated Pwm_Cfg.h file for the MSPM0G351x configuration.
Could you please verify this issue and advise if there is a workaround or patch available to restore the missing channel ID defines?
Thank you for your support.
Best Regards
Prashant Singh Tomar
