AWR1843BOOST: To change the FOV in MRR demo
Part Number: AWR1843BOOST
In MRR demo is there any way to control the azimuth FOV like in OOB demo.
Thanks & Regards.
Rehman
    The MRR demo does not have control for FOV like in OOB demo.
    The OOB has control to REDUCE the FOV by filtering out detected points which are not in a certain area of interest.
    It is not possible to increase the FOV through basic software because FOV is defined by the antenna.
    So, if your purpose is to increase the FOV this will not be possible.
    If you purpose is to reduce the FOV, then you can add some code after (x,y,z) is computed and remove the values you desire.
    Thank you
    Cesar
  • Hai Cesar,
    Yes, we know that there is no chance of increasing the FOV, we wanted to know whether we can reduce the FOV.
    We will filter with X and Z axis.
    Rehman
