Hi
After searching through the forum, I found that the SDK samples that worked for AWRL1432-BOOST board will not work with AWRL1432-BOOST-BSD. I would like to understand why. As I see it, the antenna geometry is the only major difference between the two boards. The SDK remains the same. What is the other difference that prevent the SDK samples (esp. MPD) from functioning in the BSD eval board?
