Other Parts Discussed in Thread: AWR1843BOOST,
can you please advise if this board needs to be returned for RMA?
Our customer purchased this board together with the AWR1843BOOST,
Per cusotmer:
"I have checked the AWR1843Boost, and it's working perfectly. I can see the data in the mmWave Visualizer.
However, when I connect the DCA1000evm, none of the lights from DATA_TRAN_PRG are lighting up.
Initially, it was the lighting, but after the burning smell, none of the lights from DATA_TRAN_PRG of the FPGA lit, while the 5V LED of the FPGA is
still lighting green.
SN of the FPGA board is 1925DCA1000EVM0505.
Can you please advise on this? Would the burning small hint to a shart on the board requiring an RMA?
Thank you
Bast regards
Adnan
