AWR2243BOOST: Post Proc false reflections
Part Number: AWR2243BOOST
Other Parts Discussed in Thread: DCA1000EVM,
Good day!
I am getting some false reflections on my current setup. The constant nature of these reflections seem to suggest I misconfigured the data format of my capture. I have the format set to "Comple1x". Is there any configuration that I missed?
Setup:
- Capture card: DCA1000EVM
- Sensor module: AWR2243BOOST REV A
- mmWave Studio: 02_01_01_0
- Firmaware version: 02_02_05_00
Configured via Lua script
--BSS and MSS firmware download
info = debug.getinfo(1,'S');
file_path = (info.source);
file_path = string.gsub(file_path, "@","");
file_path = string.gsub(file_path, "DataCaptureDemo_AWR2244.lua","");
fw_path   = "C:\\Users\\LaptopPC\\Downloads\\mmwave_dfp_02_02_05_00\\rf_eval\\rf_eval_firmware"
--Export bit operation file
bitopfile = file_path.."\\".."bitoperations.lua"
dofile(bitopfile)
ar1.frequencyBandSelection("77G")
--ADC_Data file path
data_path     = file_path.."..\\PostProc"
adc_data_path = data_path.."\\test_data.bin"
-- Download Firmware
BSS_FW    = fw_path.."\\radarss\\xwr2xxx_radarss_rprc.bin"
MSS_FW    = fw_path.."\\masterss\\xwr22xx_masterss_rprc.bin"
-- Download BSS Firmware
if (ar1.DownloadBSSFw(BSS_FW) == 0) then
    WriteToLog("BSS FW Download Success\n", "green")
else
    WriteToLog("BSS FW Download failure\n", "red")
end
-- Download MSS Firmware
if (ar1.DownloadMSSFw(MSS_FW) == 0) then
    WriteToLog("MSS FW Download Success\n", "green")
else
    WriteToLog("MSS FW Download failure\n", "red")
end
-- SPI Connect
if (ar1.PowerOn(1, 1000, 0, 0) == 0) then
    WriteToLog("Power On Success\n", "green")
else
   WriteToLog("Power On failure\n", "red")
end
-- RF Power UP
if (ar1.RfEnable() == 0) then
    WriteToLog("RF Enable Success\n", "green")
else
    WriteToLog("RF Enable failure\n", "red")
end
if (ar1.ChanNAdcConfig(1, 1, 1, 1, 1, 1, 1, 2, 1, 0) == 0) then
    WriteToLog("ChanNAdcConfig Success\n", "green")
else
    WriteToLog("ChanNAdcConfig failure\n", "red")
end
ar1.RfLdoBypassConfig(3)
ar1.LPModConfig(0, 0)
if (ar1.RfInit() == 0) then
    WriteToLog("RfInit Success\n", "green")
else
    WriteToLog("RfInit failure\n", "red")
end
RSTD.Sleep(1000)
if (ar1.DataPathConfig(1, 1, 0) == 0) then
    WriteToLog("DataPathConfig Success\n", "green")
else
    WriteToLog("DataPathConfig failure\n", "red")
end
if (ar1.LvdsClkConfig(1, 1) == 0) then
    WriteToLog("LvdsClkConfig Success\n", "green")
else
    WriteToLog("LvdsClkConfig failure\n", "red")
end
if (ar1.LVDSLaneConfig(0, 1, 1, 1, 1, 1, 0, 0) == 0) then
    WriteToLog("LVDSLaneConfig Success\n", "green")
else
    WriteToLog("LVDSLaneConfig failure\n", "red")
end
if (ar1.SetTestSource(4, 3, 0, 0, 0, 0, -327, 0, -327, 327, 327, 327, -2.5, 327, 327, 0, 0, 0, 0, -327, 0, -327,
                      327, 327, 327, -95, 0, 0, 0.5, 0, 1, 0, 1.5, 0, 0, 0, 0, 0, 0, 0) == 0) then
    WriteToLog("Test Source Configuration Success\n", "green")
else
    WriteToLog("Test Source Configuration failure\n", "red")
end
if(ar1.ProfileConfig(0, 77, 100, 6, 60, 0, 0, 0, 0, 0, 0, 29.982, 0, 256, 10000, 0, 0, 30) == 0) then
    WriteToLog("ProfileConfig Success\n", "green")
else
    WriteToLog("ProfileConfig failure\n", "red")
end
if (ar1.ChirpConfig(0, 0, 0, 0, 0, 0, 0, 1, 1, 0) == 0) then
    WriteToLog("ChirpConfig Success\n", "green")
else
    WriteToLog("ChirpConfig failure\n", "red")
end
if (ar1.EnableTestSource(1) == 0) then
    WriteToLog("Enabling Test Source Success\n", "green")
else
    WriteToLog("Enabling Test Source failure\n", "red")
end
if (ar1.FrameConfig(0, 0, 8, 128, 40, 0, 0, 1) == 0) then
    WriteToLog("FrameConfig Success\n", "green")
else
    WriteToLog("FrameConfig failure\n", "red")
end
-- select Device type
if (ar1.SelectCaptureDevice("DCA1000") == 0) then
    WriteToLog("SelectCaptureDevice Success\n", "green")
else
    WriteToLog("SelectCaptureDevice failure\n", "red")
end
--DATA CAPTURE CARD API
if (ar1.CaptureCardConfig_EthInit("192.168.33.30", "192.168.33.180", "12:34:56:78:90:12", 4096, 4098) == 0) then
    WriteToLog("CaptureCardConfig_EthInit Success\n", "green")
else
    WriteToLog("CaptureCardConfig_EthInit failure\n", "red")
end
if (ar1.CaptureCardConfig_Mode(1, 1, 1, 2, 3, 30) == 0) then
    WriteToLog("CaptureCardConfig_Mode Success\n", "green")
else
    WriteToLog("CaptureCardConfig_Mode failure\n", "red")
end
if (ar1.CaptureCardConfig_PacketDelay(25) == 0) then
    WriteToLog("CaptureCardConfig_PacketDelay Success\n", "green")
else
    WriteToLog("CaptureCardConfig_PacketDelay failure\n", "red")
end
--Start Record ADC data
ar1.CaptureCardConfig_StartRecord(adc_data_path, 1)
RSTD.Sleep(1000)
--Trigger frame
ar1.StartFrame()
RSTD.Sleep(5000)
--Post process the Capture RAW ADC data
ar1.StartMatlabPostProc(adc_data_path)
WriteToLog("Please wait for a few seconds for matlab post processing .....!!!! \n", "green")
RSTD.Sleep(10000)
