Other Parts Discussed in Thread: IWR6843AOP, UNIFLASH
Dear TI Support Team,
I am currently working with the IWR6843AOP device.
I have successfully flashed the 3D_People_Tracking\prebuilt_binaries using UniFlash.
The SOP switch is set to 101 (Functional mode) and the device was power-cycled after flashing.
When I connect the device to the Body and Chassis Visualizer and press Start, the following issues occur:
ERROR: No data detected on COM Port, read timed out
Be sure that the device is in the proper mode, and that the cfg you are sending is valid
Environment:
Demo: 3D People Tracking
SOP setting: 101
COM Ports: CLI=COM3, DATA=COM4 (confirmed in Device Manager)
- cfg: AOP_6m_default.cfg
Despite these steps, the same error persists.
Could you please advise whether this is caused by a mismatch between the firmware and configuration file, or if there might be another issue with my setup?
Thank you very much for your support.
Hidetaka
