Other Parts Discussed in Thread: IWR6843, MMWAVEICBOOST, IWR6843ISK, , IWR6843AOP
Check compatibility: Confirm that the connectors on your IWR6843 EVM are compatible with the MMWAVEICBOOST. On some revision "D" versions of the IWR6843ISK, the 60-pin connectors are not perfectly aligned for direct connection. While it may be possible to use only one connector (J4) for basic UART and reset functionality, this is not the standard procedure. If you encounter this issue, check the TI E2E support forums for guidance.
This is what the Google AI returns when I do a search. Check back here on the E2E TI support forums, so I am.
Basically, the 60-pin connectors have a bevel on the "bottoms" on the MMWAVEICBOOST board, but on the IWR6843AOPEVM board the corresponding connectors have their beveled sides pointing in opposite directions (unlike on the MMWAVEICBOOST.
I don't think I should unsolder with wick / solder back one connector the other way (flipping it) because of solder bridges, etc. The pins are very small.
So, any advice / suggestions on what to buy to remedy this?
