Part Number: TMP112
For the TMP112 I²C timing spec, the datasheet lists t(HDDAT) (data hold time) as 100–900 ns(as table in Section 6.6).
I would like to ask: Is there any risk if t(HDDAT) is below 100 ns?
Thanks.
Part Number: TMP112
Hello Wills,
Could you please tell me more about your setup? How many devices will you be using and are you using Fast Mode (Standard Mode) or High-Speed Mode? Depending on the setup there could be some risk if the data hold time is lower than 100ns in Fast Mode since performance cannot be guaranteed below the recommended hold times.
Harry
Hi Harry,
Thanks.
Hello Wills,
Could you please share the date/lot code from the packaging of the devices in your possession?
Harry
Hi Harry,
We are not able to retrieve the date code or lot code for the TMP112 units, as the original packaging is no longer available.
Also, may I confirm: the tHD;DAT behavior should not be related to device date/lot code, correct?
I assume this timing parameter is defined by the device design/specification rather than a manufacturing-lot‑specific issue.
Hello Wills,
I'm going to move this post to email and will follow-up with you soon. Please keep an eye on your inbox in the meantime.
Harry
