Part Number: DCA1000EVM
Other Parts Discussed in Thread: IWR6843AOP, AWR1642BOOST
hi
sorry for late reply for my last question. But i have same problem as last time.
I am experiencing a severe and repeated hardware issue with the DCA1000EVM.
Previously, my original DCA1000 failed because the L4 component was severely overheating. Assuming it was a faulty board, I purchased a brand-new DCA1000.
The new board worked perfectly at first. However, it is now exhibiting the exact same symptoms as the first one:
The L4 component is overheating again.
The Ethernet connection is failing completely.
Since this has happened to two separate boards, I suspect something might be causing this component to burn out. Here are my questions:
Can this board be repaired, or should I request an RMA?
What is the specific function of the L4 component?
What external factors (e.g., specific power supply issues, connection to the radar EVM board) could be causing this exact component to continuously fail?
Any guidance on troubleshooting this or initiating a repair would be greatly appreciated.
Thank you.
