Does anyone has the IBIS model for LM75CIM-3? I know it's now obsolete, but need it to troubleshoot an i2c issue we have. I searched both National Semi and TI but cannot locate it. Thank you!
Tony
Hi Tony,
If this is a new design I highly recommend that you switch to the LM75AIM. You will not need to carry two parts in your inventory as this part works well with a wide supply range.
Here is the URL for the LM75B ibis model:
http://www.national.com/assets/en/tools/ibis/lm75.ibs
I need a few days to double check to see if this applies 100% to the LM75A as well. But this will give you a start as I don't expect much changes. These models are typical models anyway.
Take care,
Emmy Denton
Precision Systems BU
Precision Signal Path
Silicon Valley Analog (formerly National Semiconductor)
We want to use "TMP101" as our new temp sensor to replace "LM75CIM-3". We had some issues with LM75CIM-3 and would like to get the IBIS model so we can perform signal integrity analysis. I can find LM75B IBIS model but not sure if it's suitable to model the older LM75CIM-3.
Do you (National or TI) still have the now obsolete LM75CIM-3 IBIS model? Or is the LM75B is also good in this case. Thank you.
Emmy Denton said:Hi Tony,
Take care,
Emmy Denton
Take care,
Emmy Denton
Hi Tony,
I scrounged around and came up with this model "lm75C-usingLM80.ibs" It's based of the LM80 witch has the same input models. The SDA output modle though will not behave the same. I hope this helps. I'll upload the file to the forum. If I can't I'll have someone else do it tomorrow.
Take care,
Emmy Denton
Precision Systems Applications
Silicon Valley Analog, Texas Instruments
Hello Tony,
Here is the file that Emmy mentioned.
Ian Williams
Linear Applications Engineer
Precision Analog and Sensing Products
