Hello--
In reading the guidelines SBOU108 and forum history, I see that assembly using flux only is the documented process.
Is there a problem using normal SAC305 paste with organic water-clean flux?
If the PCBA stencil is excluding the TMP006, then assembly would likely need a second pass to apply flux only before placement.
Might it make more sense to follow the EVM, and have the TMP006 on a separate little PCBA that uses
the flux-only process? How does TI spec the EVM assembly?
So many questions, so little time before production... :-)
TIA again -- Joe
